Hey, i have a legacy blue amp 1000Watts i hooked it all up and the lights came on so it works and it powers my 6/9's bc they are hooked up to the head unit and the little blue wire is too but when i hook up a sub the red light comes on and wont work. soo any solutions please.
k thanks. ill check that tonight but the blue wire is the accessory wire and behind the head unit is 2 more wires that we tied together and idk what that did just listen to my brother. i was messing with it alittle now the light turns green but still nothing from the subs. Thanks aganink thanks. ill check that tonight but the blue wire is the accessory wire and behind the head unit is 2 more wires that we tied together and idk what that did just listen to my brother. i was messing with it alittle now the light turns green but still nothing from the subs. Thanks aganin
You can't post conmments that contain an email address.
I think the blue wire is a standby "on" to be hooked to separate or system switch. Without knowing how you have system wired, I can' offer much. A bit of caution; having a thousand watt amp hooked to 6x9 dooms their fate
4000 watt amp that was 2-channel with 2000 watts peak and 1000 watts RMS per channel, when wired as 4-ohm, which is what the sub's ratings are based on. therefore the amp and sub configuration were a perfect match, however approximately 1/2 an hour into driving with them i noticed a plastic/rubber burning smell and immediately shut off power to them. upon inspection both subs were blown and completely unusable. this leads to the conclusion that they were poorly rated and of poor quality materials, and i hereby advise that unless your going to run way under the limits, they are no good!
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
what product brand did you install. do you set the amps x-over and gains a sub sonic filter right
need to see if the amp is on check led light on amp. make sure your subs ohm load is correct for the amp.
let us an example fake amp 500x2channel max output 1000watts
if you wire your subs at 4 ohms you 250x2 rms stereo
if you wire your subs at 2 ohms you 500x2 rms stereo
if you wire your subs at 4 ohm mono you get 1000 watts
if you have the input voltage of 14.4 all the time at the amp
find the ohms on each subwoofer and how much it can handle. If you have two 4 ohm subs get a powerful MONO AMP and hook it up in parallal. If you have two 2 ohm subs get a (1 ohm stable) Powerful MONO AMP and hook it up in parallel or a powerful 2 CHANNEL AMP but the wiring can be a little complicated cause you've got to connect the subs in series and bridge it on the positive of 1 channel and the negative of 2nd channel for maximium benefit without burning out the 2 channel amp. If you got two 500 Watt subs then you got to find an amp that can put out 1000Watts anything less wont sound good and may burn out the subs because of too much distortion cause of lack of power.
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Make sure that when you hooked up your 4 channel amp to the remote turn on lead it is the same as the sub. Only hook amps to the Blue w/ white strip. The solid blue is power antenna lead and will lose power when on CD, ipod etc and only stays powered when the Tuner is on. Hope this fixes your problem.
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
