20 Most Recent Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier Questions & Answers
If it is a mono amp, it is already bridged internally.
Sony Xplod Car... | Answered on Oct 17, 2011
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
Sony Xplod Car... | Answered on May 13, 2011
The fuses should be 30Amps each and they are there as a protection system in case of a power surge. They will blow before damaging your amplifier. However it is not a 100% fail safe proof.
Sony Xplod Car... | Answered on Feb 04, 2011
It could be the wiring. Sony amps will go into protection if the ohm is to low. They usually like to see 4 ohm or higher. Unplug your speaker wires and see if it still stays in protection. If it does could be an internal thing in the amp. If it isn't rewire subs in series not parallel.
-david
Sony Xplod Car... | Answered on Nov 09, 2010
Unlike the stereo unit, amps doesn't have a reset button.
Check the fuse in your hood.
Check all wiring, especially the ground to chassis.
Check for voltages, remote turn on should have 12V to ground and power cable should have around 12 to 14 volts.
Sony Xplod Car... | Answered on Sep 20, 2010
The amp is overheating it doesn't have a built in fan. This will be more occasional in the summer months. The best solution is to build a box and buy a few computer fans, install a fuse link run the positive of the fans to a remote wire and ground the fans to the chassis of your vehicle. You need a way to recirculate the air inside your amp. I've decided to remove the bottom plate of the amp, mount the amp on a board. Cut holes out of the board and have one fan flipped to pull hot air from the amp and two fans to push the air away from the amp.
You can buy the Antec and Rocket Fish fans for under $15 from Best Buy.
Sony Xplod Car... | Answered on Aug 01, 2010
this meens that the unit is protecting your speakers from damage, unit need repair,probibly a blown channel
Sony Xplod Car... | Answered on Jun 22, 2010
well ask em nicely
Sony Xplod Car... | Answered on Jan 19, 2010
you may have a bad ground on the rca's. try running a wire from ground to the shielding if the rca's and see if it goes away. if it does, either take the amp apart and repair the ground trace, or run a wire from ground to the rca shield permantly.
Sony Xplod Car... | Answered on Nov 16, 2009
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Sony Xplod Car... | Answered on Nov 14, 2009
check first the fuse of your amplifier set maybe blown up then check also the switch of amp.
Sony Xplod Car... | Answered on Aug 15, 2009
you are getting a power surge somewhere try to use a toggle switch on the remote wire
Sony Xplod Car... | Answered on Jul 05, 2009
yes those are some of the facture to check but first i want you to disconnect all spk and rca and turn on amp and then start connting using one rca and one spk wir connect one by one and see wht happen
Sony Xplod Car... | Answered on Jun 26, 2009
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Sony Xplod Car... | Answered on Jun 04, 2009
Check the switch wire connection. It's the one that turns the amp on when you turn the head unit on.
Sony Xplod Car... | Answered on Jun 02, 2009
you can **** yourself
Sony Xplod Car... | Answered on Mar 09, 2009
For some reason it has gone into protection mode to limit further damage to the amplifier. Remove the subwoofer wires and power on to eliminate shorted voicecoil. After checking all wires for continuity to ground, a service tech will be required.
Sony Xplod Car... | Answered on Dec 22, 2008
Sony Xplod Car Audio Amplifier XM-DS1300P5 - 800 Watts Mono Amplifier Car Audio Amplifier Logo
29 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
mean when red protection light
  • Car Audio & Video
