Televison & Video Logo
Anonymous Posted on Aug 26, 2010
We understand that your problem is: Hello, I bought a LG 42sl80yd tv from china, but now i am in Bangladesh, when i tune tv programm it tune ok, antina and cable connectivity, but its sound is not ok, as far i know Bangladesh used BG system sound, but in tv has no BG option, it has only DK, I, M, . So how can i solved it, please send me soluation as soon as possible, [email protected] is my email id, plzzzzzzzzzzzzzzzzz.sa
  • Anonymous Feb 18, 2012
    Hello Sir,
    I bought LG 42LV355T 42-inch Widescreen Full HD 1080p LED TV from UK.
    I tried to set up it in Dhaka. But cant.
    So, I need your help. Plz if possible then give the sollution.
    email: [email protected]
Dusmantha Anandaratne
Level 2:
  • Expert 70 Answers
  • Posted on Aug 26, 2010
Expert
Level 2:
Answers
70
Questions
0
Helped
16221
Points
140
PAL B use 5.5 Mz and 6.5 Mz in DK and I so you need modfy the sound if section removing 6.5 Mz ceramic filters with 5.5 Mz fiter and so on better way buy old VCR and connect video out and audio out to your LCD and put AV to view the TV channels
  • zahid6914 Dec 29, 2010
    I have the same problem Mr. Saif, I am from Dhaka, Bangladesh. And bought the same TV from china. And now facing the same problem.
    I get the solution, but If i view the TV on AV more, then I will not get most of the TV's function or features. So Is there any other way to solve the problem. Is there any software by which I can update my TV to solve this problem??
Good morning, can u help me plse i have a lg g pad 8.0 i want to know can i make phone calls from it
Hello, friend! I happened to see you with this problem, I also meet this error about my cell phone, I get many help from this forum, and also bought many DIY repair tools from china supplier , and vipprogrammer help me fix this error. maybe you can try it.or contact ther WhatsApp:+ 8615986801289 website: http://www.vipprogrammer.com. They've solved my cell phone problem and I hope it will help you with your mobile phone trouble.
They are free to consult, I hope that the programmers I recommend can help you.
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
How can I get authorised Acer lapto service center in Bangladesh?
Hi, there should have been warranty information with your laptop, it will read something like world wide warranty and service. Service agents in Bangladesh should be listed too
Good lUCK
1helpful
How to unlock ASM in SANSUI SV-2010K
Hello
Universal remote codes for Sansui TV with RCA RCR311B remote control are:
1020, 1054, 1133, 1145, 1167, 1230
But I really don't understand to what do you mean by this ASM lock. ASM [Automatic Search Memory] is meant for tuning fuction. When we put the set to ASM mode, it should search all the available programmes at that time at appropriate chanels, and will stop; must stop; at the end of the tuning is over, and must show the first received programme. Then we can change the programmes as our own select. If ASM function does not works with your TV as specified above, surely its memory IC is in trouble; damaged; and should replace it with same type and number. This IC is an eight terminal one, can be located very near to main system control IC of your set. OK.
1helpful
I bought a LG from HK and brought to Bangladesh, now its showing that its only have Sound System D/K, but in Bangladesh, its B/G, therefore, I cant hear any sound! Any solution? Thanks! PAPPU
LG has auto system tv, if auto store still not support, i suggest you to manual search and select sound system to B/G, or reset all seting to default seting . If still problem, upgrade new software may solve your problem.
Or ask LG technician to check your setting.
1helpful
2answers
Hello .i have a lg tv which i purchased in 2008 and only watched videos,i now want to watch tv i have tried auto tune and it only finds 3 vhf channels and none digital.it has preview built in but i can not...
if it has freeview built in its usually programmes itself try turning it on and go into the menu and there should be an auto tune function hit that and it should tune up but remember it needs to be connected to an aerial if it still says no signal try moving the aerial, getting a booster for the aerial they usually plug into the mains then into the back of your tv and you plug your aerial into that to boost the frequencey if that doesn't work then you might need to think about getting a new aerial but you can get 1 for under £30
12 channels are turned on the rest have been deleted, how do I turn them back on?
Hello
Go through your TVs operation manual. and set it to auto tune. It will regain back all the channels cleared after the complete tuning process. Wait for to tune for all bands. Never interupt the process until search process ends and displays the first programme got by it on the screen. Ok.
Sony KV-28LS36U problem finding programms and no sound
Make sure that in menu section on your tv, that you choose channel settings then the right setting are selected such as cable, air or whatever you are using in your area for receiption.
3answers
Toshiba that uses CT-90040 remote
Is the cable remote a programmable universal? If so, just a matter of finding the codes to reprogram functions.
Concerning the "tuning video", are you saying that you can't get to different input sources?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
