SOURCE: changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
SOURCE: JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
SOURCE: Conversion kit or fix for LP to NG for the Char-Griller
I removed the jets and drilled them out, #54 is what I started with and then moved up from there to get a good flame( gas pressure may be diffrent in your area). I went to lowes and purchased the universal gas line for grills. Item #: 206469 from lowes, I removed the hoses from the valves, and proceeded to remove the regulator from the hose. After that, i used a 1/4" npt coupling, and a 1/4/" NPT to 3/8" Flare fitting( fits to hose).
I drilled a hole in the brace that is under the clamshell(it says UP) that way I had a place to relive stress from the hoses. I threaded the Coupler to the Y then threaded the Flare fitting thru the sheet metal and then the coupling. This was an easy mod minus the garage in disarray, my precision calipers on loan, and 3 trips to the hardware store. The connection that goes to the house is a 3/8" NPT Female, my house has 1/2" pipe, The one wasted trip to the store is because i didnt bring the fitting with me to the store and assumed the size was 1/2 to 3/4(Rookie Mistake).
It was 35 degrees when I finished this mod, and on high for all 3 burners, I got it to 675F in a hurry. the needle was still creepin up, but that is when I said that was good enough for me.
I used my lathe to drill out the jets, ksware is correct with how easy the jets break. I broke the one in the side burner. I will make another one when I get an hour or two. Good luck to you and happy grilling.
Little Elm, Tx.
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
SOURCE: I bought a Char Broil
The conversion kit has one orifice for the side burner. The two maim burners are sized for natural gas once the LP orifices are removed. Joe
