Brother CS-80 Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to calibrate the bobbin with the needle. is there an easy way to do this. i changed the belt which is why it is out of sync.
Anonymous
Level 2:
  • Expert 240 Answers
  • Posted on Aug 16, 2010
Anonymous
Expert
Level 2:
Answers
240
Questions
Helped
93295
Points
779
There is no easy way to calibrate. the whole system is simply mechanics so you'll have to take the belt off, calibrate manually and reinstall the belt carefully not to throw anything off.
Thanks,
Pat
The tension on the top is out of sync. Don't know what to adjust. Help
Since we don't have a clear picture of what is happening, we can't offer much in the way of advice. Here is something to try:
Remove the top thread from the machine.
Be sure to install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread from the beginning. Verify the thread path is correct.
Remove the bobbin and rethread it into the bobbin case and install it in the machine. Make sure the bobbin is turning the correct direction in the bobbin case.
Set the top tension to the midway point (the factory standard tension).
Retest the machine.
HINT: Thread issues appearing under the fabric are usually a top thread problem. Thread issues appearing on top of the fabric are usually bobbin related.
If top thread is showing under the fabric, tighten the top tension.
If bobbin thread is showing on top of the fabric, loosen the top tension.
If problems continue, the bobbin tension may also need to be adjusted. HOWEVER, that is a last resort and a very tricky change to make. Be sure to mark where the tension screw is set BEFORE making any changes to the bobbin tension screw (so you can reverse your changes if it doesn't work).
You can also try changing the type & size of needle and the brand/weight of thread. AVOID old or bargain bin threads. Your needle choice, thread, and fabric should be compatible. Using the wrong needle can cause huge problems with stitching success.
Understanding Thread Tension Threads
1helpful
7answers
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
1helpful
Singer 144w305. Try to use reverse and the thread binds up under neath and breaks instantly. Take the belt off the machine spins free and easy by hand. Out belt back on and it is hard to turn by hand.
check the bobbin / needle thread tension.
IN most machines the reverse is just for the feed as the needle and bobbin still spin in the same direction
1helpful
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
2answers
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
2answers
I need to thread an elna air electronic su sewing machine
that's a nice machine, one of the last mechanical Elnas with the discs for extra stitches. Firstly, you need to wind a bobbin, always use Elna swiss metal bobbins, with holes on one side only, slightly dished. Put on top of the bobbin spindle and take the thread from your spool on the spool holders at the back of the machine across to the tension disc on top left, its white bump, thread through the tension then back to the bobbin and pull the tail through a hole in the top of the bobbin. Flick bobbin across to the right against the stop, disengage the clutch by holding the outer flywheel and turning the inner towards you. Now press the foot pedal to start winding a bobbin, holding the thread tail so it starts off. Wind one full coverage of the bobbin so that the starting point is covered, then stop and cut the tail off with scissors. Now continue winding at 3/4 speed until bobbin is full, watch as it winds and give the thread a nudge with your finger so it fills top and bottom as well as in the middle of the bobbin. When it is full, the bobbin spindle will stop winding. Move it to the left, cut the thread and reennage the clutch by holding flywheel and turning the inner the other way. Now install the bobbin and click the thread into the tension device, see image.
Now thread up the top thread by taking the top thread from the spool, through the tension discs, across to the eyelet on top, down to the check spring, back up to the take up lever, then down to the needle catching the thread into the two thread guides enroute.
See this image.
Now thread through the needle front to back, hold the top thread, close the bobbin cover leaving the tail sticking out the top, lower the needle down by turning the flywheel towards you through one cycle and pull the top thread, drawing the bobbin thread up to the top of the needle plate with it. Pull both threads under the pressure foot to the back and your ready to go. Remember, top tension should be on 5 and bottom tension should be on the red 1, don't change it. Brush out the bobbin holder assembly each time you use this machine and add one drop of oil into the middle of the bobbin holder, there may be a red dot or just the indenation. Run the machine for 30 seconds after oiling without thread, slowly to spread the oil through the bobbin mechanism. Standard 130/704H needles, change regularly (6 hours of sewing) and pick right sized needle and type point for the work you are sewing. Good luck with your SU. If you wanted to join, there is a Yahoo group called "Elna Heirlooms" for fellow Swiss Elna owners.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
