Lately when I click on something both with mouse or touchpad everything goes crazy jumping and won't stop. For instance when I clicked on my email to open one it just kept going right through all of it as if I had read it.Can't control anything once it starts like signing off my Internet provider.
Didn't need to try solution. It appears the batteries in my mouse may have caused the issue. I put new ones in and so far have not had any issues with cursor going crazy.Didn't need to try solution. It appears the batteries in my mouse may have caused the issue. I put new ones in and so far have not had any issues with cursor going crazy.
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Click Start/Control Panel and adjust the mouse touchpad.
I would set it to the default settings. If it still acts crazy download and reinstall the drivers.
Get onlineand got to www.google.com In the google search box type: "DellSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad drivers.
This issue could be due to corrupt Touchpad drivers or corrupt Touchpad sensitivity settings or corrupt BIOS settings. To isolate this issue, please perform the steps provided below: 1. Uninstall and reinstall touchpad driver on the notebook. 2. Decrease the Touch Sensitivity of the Touchpad. If you are using Windows Vista on your notebook then you can follow the steps listed below for decreasing the touch sensitivity of the touchpad: a. Click Start and type ?Mouse? without quotes in Search field. b. Click on Mouse from the results list. c. This will open d. Click on Tapping tab in the Mouse Properties window. e. Click the Touch Sensitivity Button to launch Touchpad settings. f. Move the slider to the desired setting (in between Light touch to Hard touch) This will adjust the Touch sensitivity of the touch pad. Now check for the issue. 3. If the issue persists, then update BIOS on your notebook. To update BIOS, go to the HP drivers download page for your notebook model and then download and install the latest available BIOS update.
Hi. I think the problem for your touchpad is just some settings on it, if your using the Synaptics driver for your touchpad you can check the option on the synaptics setting where you can disable your touchpad while you are typing or doing something else on your keyboard. If you could not find this options or settings on your laptop you could just download a software that does the same thing, disable your touchpad while you are typing so that it would not go erratic. here is the link http://tinyurl.com/nte6wu, click on this link it will redirect you to a website where you can download the software, but that is only if could not find the option on your touchpad settings, by the way try also your control panel and look for the mouse icon then for your touchpad settings. Hope this helps
Click on the start menu and select "Control Panel". Once in the control panel, select "Hardware and Sound". Once in the hardware and sound menu, click on "Mouse". Once the mouse menu comes up, there should be a tab labeled "Dell Touchpad". Click on that tab and then click on the large touchpad icon to take you to the touchpad options. Once in the touchpad options menu, click on "Device Select". Once you click on deivce select you should see the option to "enable" or "disable" the touchpad.
the easy method would be to hook up a USB mouse and disable the touchpad to see if that works. Control Panel -> Mouse (or Printers and other Hardware), then click on the mouse and then click on Advanced or Hardware tab to look at the options. You might be able to have it disable the touchpad when a mouse is present.
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc.
Both touchpad and keyboard will be reinstalled and then ready to use again as it should be back to normal
Possibly dust might have infiltrated into your touchpad. If you have the necesarry technical experience you could remove the touchpad and clean it and re-install it. another option would be to replace it or otherwise plug-in an external mouse and use that. Thanks.
Dont give much pressure or harder press over the area and on the keyboard on your laptop. If any pressure on top area will makes your touch pad to start working all laptop has it option to off it . Also make your mouse sensitivity very low - if you set it in high a small movement or any kind or pressure over that can make it on.
