WARNING when replacing a motor on a northstar you must match the hp and service factor.. say its a 1.1/2 hp motor and the service factor 1.47 you will need a 2hp with a 1.15 service factor to replace that original motor .if you replace it with a 1 1/5 motor it WILL BURN UP THE MOTOR !!. welcome to the hayward northstar .
only the 2 speed motors have a start switch the CAPACITOR would be my first check it may be a 30 or a 35uf at 370 cap LOOK IN YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING USE YOUR ZIP CODE IN YOUR SEARCH
HAD THE MOTOR BEEN REPLACED ? WHAT IS THE PRESSURE ON THE FILTER (LBS) DO YOU HAVE SOLAR, HOW BIG OF POOL GALLON , IS IT SCREENED IN, SPA, HOW MANY PUMPS ?
