Only 2 yrs old worked fine until today motor wont run I can hear it click on then it gets hot
SOURCE: my polaris booster pump will not come on. when i
Does it have a century motor? If so, remove the shaft cover plate at the rear and try rotating the shaft with a very thick slotted screwdriver or substitute until it turns fairly easily. Often some mild oxide develops around components that just needs to be disturbed.
SOURCE: looking for wiring instructions for the
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
SOURCE: polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
SOURCE: Pump comes on for about a minute...then shuts off..
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
SOURCE: wiring diagram for Polaris booster pump
http://www.electricmotorwarehouse.com/PDF/polaris_manual.pdf
If you goto this link and scroll down to page 4, it shows what the wiring is.
Hope this helps. If so, please rate me for this.
Thank you for posting your question here on Fixya.com.
When you installed it were you careful to set the motor to the correct incoming line voltage? If not and you are powering it with 115V you probably didn't reset the motor for 115 from 230...factory set motors come out for 230 V. A motor set for 230 but running on 115 will be very hot and over time will begin to cycle its overload. The performance will be poor until corrected. Look for a dial in the terminal area or wires to be reconfigured. Directions for how to set the motor voltage should be found on the motor nameplate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
