Onkyo TX-SR804 7.1 Channels Receiver Logo
Posted on Apr 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Receiver shuts off on its own
It has been fine, for over a year. This week it has begun shutting off on its own, and the red stand by light blinks. I'll be watching TV for a little while and it just shuts itself off and the stand by light starts blinking. Nothing I read in the manual seems to fit this scenario exactly. I haven't reset the receiver, but I have unplugged it for a day then hooked it back up and it worked for an hour or so then shut down again. Is there something I can do?
Anonymous
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 27 Answers
  • Posted on Aug 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Teacher:
Answers
27
Questions
0
Helped
20463
Points
44
I have the same receiver and the way to fix is simple. in the main board of this unit there are 5 connectors and they slide into other components like Lego. the issue is the king of material they are made of it's cheap. if you reseat the mainboard it will fix it for a day or two, them it will start again. the easyway is to re seat the board and put a fan inside of the receiver between the transformer and the inside of the amp pointing down about 20 degrees connect the fan to a ajustible voltage adapter and connect it to the outlet in the back of the unit. so it comes on when you turn it on. this voltage adapter is cheap. the adapters people buy for phones and or MP3's at Radio shack or Best buy it goes from 1.5v to 12 volts/ this way you can control how loud the fan is in side the receiver. i find 4.5V does the trick. The connectors on this board start to loose contact with some of the pins when heated. the fan keeps it cool enouth to fix the issue. I fixed manny these ONKYO 804's this will fix it. you just have to do it. the main board is inder the HDMI board in a Vertical position running from one side to almost the Power supply. it has 2 screws also holding it in the inside middle back of the amp. Becarefull with these amps 75 V at 23amp's DC is no joje leave it off for a couple of hours to satart working on it. Good luck.
toriless
Level 2:
Sergeant:
  • Expert 290 Answers
  • Posted on Mar 01, 2009
toriless
Expert
Level 2:
Sergeant:
Answers
290
Questions
0
Helped
64319
Points
726
Yeah, it's clearly either overheating or shorting out and turning itself off before it gets damaged. It'd first make sure it's cool enough since these unit pump out a LOT of heat and then check speaker cables.
A
Anonymous
I had this same problem it turned out my subwoffer speaker wire got unplugged!
Anonymous
Level 2:
Scholar:
  • Expert 186 Answers
  • Posted on Apr 25, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
186
Questions
Helped
65266
Points
386
Also check ventilation of the unit, it could be a self protect too due to a heat related issue....
Francisco Mauricio G
Level 3:
Genius:
  • Onkyo Master 1,551 Answers
  • Posted on Apr 24, 2008
Onkyo Master
Level 3:
Genius:
Answers
1551
Questions
Helped
525438
Points
4192
Take it to a repair center because your audio ICs amplifiers are damaged.Good luck.
2helpful
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Furnace has begun to fail to cycle on when shuts off but if switches on base of furnace are switched off and back on will cycle on until desired temp. is reached but will not come back on unless switches...
This sounds like it may be a control board issue. If the thermostat has been changed, and the unit operates correctly after it has been reset, then I am thinking the circuit board in the unit is faulty. When the unit stops working, check for a blinking or steady red light on the circuit board. Alot of the time this will be on or blinking and there will be a legend that tells you what each light stands for. This can help you troubleshoot the issue.
I have a Kenwood VR-804 surround system receiver. Stand by light keeps blinking when turned on but no sound no nothing when turned on just powers up for a few seconds then shuts off with light blinking. I...
Blinking indicates that the power source has shut itself down because another component has died and it's shorting it. Unless you have experience in electronics it's time to take the receiver to a repair shop.
3helpful
2answers
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
1helpful
2answers
Red light blinks and it shuts off after starting
I had the exactsame problem. I took it to an authorized repair place in Houston and they quickly diagnosed it and replaced the power supply.
1helpful
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Re: Denon AVR-1100 receiver Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and...
The receiver has gone into a protect mode because something is wrong and it shuts down to prevent further damage. Could be a power supply or output amp issue.
SX-SR604 KEEPS SHUTTING OFF
Los amplificadores de audio estan empezando a fallar.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
