FixYa.com
Onkyo TX-SR604 7.1 Channels Receiver
All Products > Onkyo > Receivers
Problems with Onkyo TX-SR604 7.1 Channels Receiver?
Get a Replacement
Troubleshooting and Support
Solved Problems for Onkyo TX-SR604 7.1 Channels Receiver RSS Feed Post a New Problem
SX-SR604 KEEPS SHUTTING OFF
MY UNIT KEEPS SHUTTING OFF AND GOING INTO STANDBY WITH STANDBY LIGHT BLINKING AND EVERY FEW MINUTES WILL TURN OFF. I...
1 Solution
cable connection to Onkyo TX-SR605 7.1
I recently purchased the Onkyo TX-SR605. This is my first experience with home theater. I have a 32" Akai lcd...
1 Solution
Automatic shutdown
When I am in dvd mode, playing a movie, every 5 minutes or so, the receiver randomly just shuts off? Thanks for your...
1 Solution
onkyo TX-SR604
we can not take the spanish off or got the remote to work.
1 Solution
Hum from speakers
I get a significant hum from the speakers when the receiver puts out a signal to the speakers. I have the receiver wired...
1 Solution
onkyo Amp
One side of the my Amp doesn't reproduce sound at the same level as the other side. It has recently started to do this,...
1 Solution
No sound
I just set up my new Onkyo TX-SR605 and Onkyo speakers.  I've checked the wiring several times.  Connections...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Onkyo TX-SR604 7.1 Channels Receiver RSS Feed Post a New Problem
I can hear surround sound, but no speech.
I have an Onkyo TX-SR604 receiver. My cable box and DVD player are connected through the HDMI ports. I can not get...
Post a Solution
Component Video losing sync with too much...
Whenever my receiver gets a video signal with too much white in the image the component video sync to the TV drops out,...
Post a Solution
Zone2 won't play TV/Cable sound source
I am unable to get Zone2 to play TV sound from Zone2, all other inputs provide sound to Zone2 i.e. CD, DVD, and Wii in...
Post a Solution
Panasonic TV speakers don't work with...
I have a Panasonic TH-42PZ700U TV and an Onkyo TX-SR604 receiver with Harmon Karden surround sound. Best Buy installers...
Post a Solution
white line at top of tv screen when using...
I connected my Scientific Atlanta 8300HDC dvr cable box to the TX-SR604 hdmi input as well as my dvd player to the other...
Post a Solution
PS conection to receiever
Can i connect my PS3 throught my onkyo TX SR605 not 604 receiver if so where do the HDMI and anologe cables go or can it...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeReceiver
Surround SoundDolby Digital · Dolby Pro Logic II · DTS Neo:6 · DTS 96/24 · DTS · DTS ES · THX EX
Number of Channels7.1 Channels
Surround Mode Power90 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.08%
THX CertificationNo
Dimensions
Depth14.84 in.
Height6.85 in.
Width17.13 in.
Weight25.13 lb.
Convenience
Tuner Presets40 Channels
On Screen DisplayWith OSD
Tone ControlsBass & Treble
Speaker Impedance4 ohm · 8 ohm · 6 Ohm
Number of Zones2
Inputs / Outputs
Rear Input ConnectorsComposite (Video) x 4 · S-Video x 4 · Digital Coaxial x 2 · RCA (2 Audio Channels) x 5 · Component x 3 · Digital Optical x 3 · HDMI x 2
Surround Analog Inputs7.1 Channels x 1
Preamp OutputsSubwoofer
Rear Output ConnectorsComponent x 1 · Digital Optical x 1 · RCA (2 Audio Channels) x 4 · Composite (Video) x 3 · S-Video x 3 · HDMI x 1
Front A/V ConnectionsHeadphones x 1 · Composite x 1 · S-Video x 1 · Couple RCA Jack x 1 · Optical x 1
Component Video Bandwidth50 MHz
Remote Control
DesignKeypad
Remote Control TypeMultibrand
Onkyo Contact Information
Main support number201-785-2600
Support FAX201-785-2650
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
