Sony KP-51HW40 51" Rear Projection Television Logo
K
Kristin WALKER Posted on Feb 27, 2014
TV turns red,shuts off, stand-by light blinking 8Times
My screen is red, TV shuts off after 5-10 seconds & the Stand-by/timer light on the front of the TV is blinking 8 times, pauses, then blinks 8 times(red blinking light) we just adjusted the convergence about 3 months ago & the picture has been great! No warnings. It seems as tho the # of blinks is the code to the problem, do you know what the issue is? or what the 8blinks means? THANK YOU SO VERY MUCH!
1 Related Answer
Anonymous
  • Posted on Oct 03, 2008
SOURCE: there is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
replace 2amp fuse
4helpful
2answers
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
When you turn the tv on the red light on the front(stand by/timer)flashes and the tv starts to come on and then it turns off.
Do you mean the screen turns on briefly or the stand by light just keeps blinking. If the tv turns off after switching on then it probably means a protection circuit fault. Also please provide me the number of times it blinks before it pauses. Awaiting your resposnse.
Regards,
Sai.
2helpful
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Tube 27" sony tv, stand by timer light blinking red?
It has a faulty power supply or processing boards. Must take to agents to sort out. Nothing you can do on the outside.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Sony shuts off after being turned on, stand by/timer light blinks
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Thanks,
Dan
3helpful
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
TV Problem
the red blinking light is a code that tells you what is wrong it will blink from 1 to 10 or just blinks all the time
2answers
There is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
Check C514 next to flyback xformer.If shorted,burnt,replace
with part # 1-161-754-00 102K / 3KV capacitor.May also have open
2 amp pico fuse in power supply......T
5answers
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
