Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Posted by kidolight on
Richard Klein
  • 360 Answers
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Posted on Oct 25, 2009
  • 2 more comments
  • Richard Klein
    Richard Klein Oct 25, 2009
    I have seen blinking problems like this before, and strange enough just replacing the power strip worked. You may want to try another power connection, or power strip too.
  • Richard Klein
    Richard Klein Oct 26, 2009
    Fuse is burned out (F6000). (G Board)
  • Richard Klein
    Thanks for specifying which light is blinking. This could be power or lighting problem.
  • Richard Klein
    Richard Klein Oct 30, 2009
    My information is good advice. If you stick with it, and give me four thumbs up you might get it fixed for free.
Anonymous
    New Friend:
Hi my tv has a stand by light on that blinks nine times. there are times that i unplug the tv for about 10 seconds and tv comes on but when i turn off the tv and try turning on the tv again, it wont turn on blinking light comes out again. i would have to try unpluging the power again until it turns on. plz help
Posted on Dec 05, 2009
When I turn on my sony kp-46wt520 tv the sound comes on for several then the red light blinks 5 times, and the tv shuts off. this problem happened gradually, it used to come on after several attempts but...
I am sorry to hear regarding the trouble. A 5 blink error code indicates a white balance error. This can have many causes such as incorrectly adjusted screen voltages on the CRT's, a bad CRT drive IC, or a bad picture tube/CRT.More often, it is due to bad driver Ic's The Ic's are labeled MCZ3001D(B) and they should be found in the middle of the deflection board.If you call a technician, the estimate cost would be around $250 - $350.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | Sony KP-46WT520 46" Rear Projection...
Led stand by light blinking
No power supply proble Google to Encompass Parts Distribution and type in your model number.
Jun 01, 2010 | Sony KP-46WT520 46" Rear Projection...
TV won't turn on, standby light just blinks 9times off and on
There is some problme in G Board (power supply board) in your Sony KP-46WT520 tv that is why standby light blinks 9 times.
If you are handy with electronics stuff repair and can test/ replace parts in circuit board then let me know to provide you more technical info to fix tv problem.
Feb 03, 2010 | Sony KP-46WT520 46" Rear Projection...
5 blinks on a sony wega KP-46WT520
needs convergence chips, stk392-570, and possibly one or more blown picofuses, you probably need a tv repairman, extensive soldering required.
Sep 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv wont turn on
Your lamp need to be check or replace it.
Jul 24, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
How do i fix my sony kp-46wt520 projection tv
Called sony and they said send it so we can help fix it.
Mine was a bad "g board"
Sent it to PA (penssylvania)
And they fixed it for & $88 you have to ship G-Board to them and they will return after they fix it if not repairable they will tell you.
(No charge until they fix it.. )
Mine works now and ready for superbowl....YEAH ! ! ! !
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
Jan 13, 2009 | Sony KP-46WT520 46" Rear Projection...
Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Light flashes 9 times
that means it has an audio error.
Dec 31, 2008 | Sony KP-46WT520 46" Rear Projection...
KP-46WT520 46 in.
Either IC708 is faulty on the A board or the two pico fuses are blown on the A board PS701 and PS702
Jun 25, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
