1. try cleaning the condenser it's gotta to have some dirt.
(if it looks clogged, turn the unit off and spray the condenser with a water hose!) it should throw out some dirt
if you did step 1 and still no cooling suspect a small refrigerant leak.
most of the times if its r-134a, i go down to autozone and buy a stop leak for r-134a and charge it into system.
also if theres a refrigerant leak,i'd get a tech to check and correct leak (if he finds it) but that's worse case scenario :) I'd go with dirty condenser.... email me at [email protected] if you need more info.
Won't cool , suspect leak, can't see where to recharge.....no valve, just a soldered pipe end. Help!!!!
Everything is clean.
I'm having a similar problem it will not cool products but the r-134a charge does not fit onto the valve
compressor comes on but buzzes an not cooling an condensor fan works
cond fan is running
