This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
2 AC power outlets offer more versatility for jobsite power
Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
USB port allows device to be charged via USB when radio is plugged into a wall outlet
Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Here is the manual for the charger - note on page 2 the meaning of the problem you describe - time to replace batteries (depends how old they are) http://download.sears.com/own/00925737e.pdf
That being said, check the videos out, perhaps can get it to work after all for a while longer.
It is very important to check the power output produced by the ac adapter. Make sure that the output voltage and ampere of the new power supply is the same with the original power supply provided with the laptop. The new power supply you purchased may be producing lower or higher ampere than the required power to turn on the unit and charge the battery.
I suggest to purchase ASUS Eee recommended power supply or ac adapter for your laptop before it gets damage by incorrect power voltage or ampere used.
Sounds like you got an incorrect power supply OR the SR16 has a failure creating too much load.
The power supply should be a 9VAC at 1 amp (1000 ma)
The power supply MAY get warm to the touch but should not get real hot.
Without the SR16 pluged onto the power supply it should barely get warm. If the SR16 doesn't work, then it probably has an internal failure... LIKELY the internal rectifier filter combination.
