NetGear WGR614 Wireless Router Logo
Posted on Jul 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to secure my wireless router - NetGear WGR614 Wireless Router
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Jul 23, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
19800
Points
122
1. Set a ssid key for wireless router.
2. Turn off DHCP option in the router, so that u can prevent unauthorized access to your network.
3. Instead give a static private IP for each user.
4. Choose wireless encryption standard such as WPA2 etc.
2answers
Where is the network security key
goto settings security ,now here enter the WEP key.
2answers
How do I secure my Dynamode BR 6004 WG1 Iam a
To secure your wireless network from unauthorized access, you need to at least configure the wireless router with encryption, and the SSID, and change the router's default login password.
Please follow these instructions :-
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA). The encryption key can be easily set up using a passphrase (it can be an alpha numeric phrase or words).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
2answers
How do you go about securing wireless network connection (linksys)
depends what security you require. just wep or wpa is simple and can be found in the security settings
2answers
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
2answers
Need to place password on wireless router. help! Router already in use for a while. just learned that i need a password.
goto router ip
192.168.1.1
admin login
admin :blank
password:admin
wireless setup
wireless security
enable wep wpa
wep 10 digit
wap 8 alpha numeric
1helpful
How can i secure a BELKIN WIRELESS G ROUTER
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
2answers
People are able to get online using my router how do i stop that
You will need to secure the wireless network. that means you need to put a password on the wireless network. Once you secure the wireless network, no one will be able to get online using your network.
To secure the wireless network, you will need to open the router set up page. on this page you will find all the wireless settings of the router.
Before changing any wireless settings on the router, make sure that your computer will be connected to the router.
If you do not have any computer connected to the router,then you will need to connect the computer to the router with the cable.
Click here for easy steps to secure the wireless network
2answers
Says not secure
3answers
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically 192.168.1.1 or 192.168.0.1) and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Security
Go to the router's web interface (192.168.1.1), in the wireless section go to Wireless Security. Enable WEP, you will create a WEP key for your wireless network, then that key will be asked to any wireless device that tries to use your wireless network.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
