20 Most Recent
NetGear WN2000RPT Repeater Questions & Answers
Netgear wn2000 states mover closer to router?
This message means your extender is too far away from your wireless router to make a good connection. Repeaters must be within a good signal range for the connection to work properly.
If you have a wifi enabled phone, tablet, or laptop, you can walk around your home and see where the signal reaches and how well. Repeaters should be placed where you still receive full or close to full signal.
Repeaters may have issues if the wireless router is on another floor, behind metal, or too far away.
12/17/2014 5:21:01 PM •
NetGear...
Answered
on Dec 17, 2014
Setup wizard
the password should be the same password of your wifi on the router...
9/2/2013 8:19:40 PM •
NetGear...
Answered
on Sep 02, 2013
I plugged in extender, waited for the green lights
It should be the password of your routers wifi... but if it did not work reset the extender back to factory default settings. .. press and hold the reset hole on the back of the extender for 15 seconds...powercycle extender.reconnect to the extenders network which netgear_extonce its connected try to run the wizard again ... u can use mywifiext.net or u can use the ip address 192.168.1.250... follow the wizard and use same settings of the existing network ... make sure u have the right key... if your using WEP for your routers security make sure you type in the key on the key 1 box during installation ... :)
9/2/2013 8:18:36 PM •
NetGear...
Answered
on Sep 02, 2013
