When the tv is on, how do i get the audio display to disappear- its keeps appearing in the upper right corner? help- and thank you,
This usually happens when you are connecting a cable box or satellite tv box to the television with a coaxial cable. In order to get this to stop you have to connect the cable box or satellite tv box to the television with an RCA/composite cable. Then you will have to change inputs to the appropriate one with the input button on the television (press it repeatedly) or with the input button on the Sharp remote (press is and then scroll down with the down arrow and press enter).
If you are not using a cable box or satellite tv receiver you can try connecting a signal booster to your coaxial cable but that is not guaranteed to work.
Enter the Service mode following the procedure below.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Information] button.
* Keep pressing the above buttons until "Initializing" appears on the display.
3) "S" is displayed in the upper right corner of the display showing the version.
4) After display of "Online", pressing the [Menu] button displays the SERVICE MODE top menu and the MESSAGE LED flashes.
