Definetely nothing works perfectly like the original part.But if you can alter accordingly it may try to lock. use a good sharp tool to make this corrrection. Otherwise you will need to check with sony service for the original part. Have you tried mending the broken one with an instant glue. most of the present day ones are very good and might stand up with a reenforcements with metal wire stuck along with a soldering iron. So try this out. Good day
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears. The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
