Dell E151FP 15" Flat Panel LCD Monitor Logo
Posted on Apr 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
15" Dell monitor
My monitor seems to be working fine except for the fact that everything is sideways. I have to put my monitor on it's side to view anything. Does anyone know how to adjust this.
It did this the other day and I just shut the computer down then restarted it, now it keeps coming up that way. I'm pretty sure it has something to do with windows because when it starts up the DELL comes across the screen the right way it's not until the desktop comes up that everything is sideways
Anonymous
Level 3:
  • Master 472 Answers
  • Posted on Apr 18, 2008
Anonymous
Master
Level 3:
Answers
472
Questions
Helped
190965
Points
1152
You have your video card set to rotate the screen after Windows loads.
Go into your display properties using it's control panel and look for the rotate section. Set it back to 0 degrees. Make sure you click apply and then OK, not just OK.
ramza237
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 01, 2008
ramza237
Contributor
Level 1:
Answers
Questions
0
Helped
159
Points
Windows XP has a funny key command that rotates the screen. Its Ctrl + Alt + any directional key (up, down, left, right) depending on which way you would like to rotate your view.
I know this works on Windows XP Home edition, not sure that it works on Professional.
2answers
The creen on my laptop is rotated sideways how do I fix it everything on my screen is sideways and i need it to be up and down so i can read my screen right side up on my laptop computer
Based on your brief description, I think your problem is correctable in the control panel under monitor settings. Depending on your operating system (XP, Vista, Windows 7) you will need to find the monitor settings and look for the advanced section for the Nvidia Video Card. In there you should find a setting to flip the monitor view between Portrait and Landscape. The settings may be named differently, but there will likely be a graphic representation to show you the different settings available.
2helpful
I have Windows 7 on a new computer. The view is sideways now.
press and hold ctrl + alt key + up arrow key. this will put your computer back to lanscape.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dell 1503FP works, but won't start up again for a few hours
Hello there.
Seems like electronics pack up but try an old one. disconnect all the data cables from your monitor side(HDMI, DisplayPort, VGA, USB etc.) or computer side if the ones on display are built-in. Leave only the power cable. Unplug the monitor`s power cable. Press the POWER button on the front of the display and keep it pressed for 45 secs. Plug everything back and give it a try.
Good luck.
I plugged my LG flatron into a dell x150. I can see up till Windows starts booting and then it cant read the signal. The dell works fine with a old sony monitor not sure why. Flatron works with every other...
If you would start the Dell in safe mode, you should be able to adjust the display settings to values that will work with the monitor. Or remove the monitor in the device manager and let windoze detect and configure the monitor on the next boot.
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
2helpful
Everything is displayed sideways on my monitor. how can I fix that ?
I suppose you have Nvidia Card Installed if yes then Right Click Your Desktop and select Nvidia select Standard Settings and go to Display + Rotate Display and set No Rotation . Thats it!
1helpful
Display on moitor
You will need to go into the display adapter from the control panel and select rotate display. Some monitors have are configurable for ceiling mounting for class rooms and other public viewing.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
