I have my system for about two year has worked fine up untill about three months ago where it just stoped reading disks everything seems to work fine except for the fact it will not read any type of disk i put in it
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
hello my is rico i work on tvs sometimes, it looks like you have bad lamp or your cooling system is work properly maybe thermal sersor. if need help fixing your tv let me know feel free to call me at 602-810-7149 anytime.
it seems thatyour getting no heat on the permanent press and gentle cycles correct? if we know the heater is working that takes care of a number of possible causes turn the power off and remove the rear panel of the dryer. you will see a couple of thermo disks mounted on the heater box.you probably will find tons of lint on these thermostats and what happens is you turn your dryer on low heat or automatic cycle where the dryer will run until it senses the clothes have no more humidity inside the drum every time the thermostat shuts off the heater the dial moves a little closer to the off position. if there is a build up of lint around these sensers the dryer will heat up until the sensers turn the heat off. what happens now is the thermostats are nice and warm as the lint buildup iacts like an insulator preventing the thermostat from calling for more heat so it will take forever to dry a load of clothes. brush the lint off the thermostats and while you are at it vacuum the back of the dryer there should be a lot of lint there
The hard drives ready for failing, back up everything now to avoid loosing data, run chkdsk /f this command will scan the disk for any problems and try to fix any bad sectors, if this doesn't work i'd think about buying a new hard drive
