Samsung HCM4216W 42" Rear Projection Television Logo
Posted on Jun 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to adjust the lens-focus? - Samsung HCM4216W 42" Rear Projection Television
Anonymous
Level 3:
  • Master 505 Answers
  • Posted on Jun 25, 2010
Anonymous
Master
Level 3:
Answers
505
Questions
Helped
120918
Points
1367
The lens has a wingnut knob on it, loosen the nut and then rotate the thing to focus in and out. there is also an electical focus in the front of the tv, there is a little black box called a focus block, 6 knobs , 3 focuses for each tube, 3 drive controls (screens).. dont turn the screens, just the focus for the color needed.. look closely they are labeled its just hard to see
the front should pop off, remove what screws you can find, the rest are snaps.. really tough ones.. let me know if you need further assistance.
  • m_ahmed1 Apr 09, 2011
    my sansung tv still has a shadow in the back ground
My Nikon D3200 will not focus?
Let me start with a guess. There is a diopter adjuster just behind the viewfinder. If it is adjusted way off from the correction you need, everything will look no better than out of focus though your photos may look fine. Google how to adjust the diopter setting on the D3200 and see if that won't take care of the problem.
Here is one of the secrets: your camera has so many adjustments that if someone else picks up your camera, they may change a setting leaving you wondering what happened and why. Be cautious.
If that guess is not the cause, let us continue. Are you saying that when you switch the lens setting from A to M, it still will not manually focus? Some of the lenses are mostly made for autofocussing, so the focus ring that you have to turn for manual focus could be narrow and out at the very front of the lens. If you cannot manually focus, something may have happened to the inner works of your lens. Try another Nikon lens to see if it will autofocus. If it does, your lens requires servicing or replacing.
Good luck. Hope you get back to shooting soon.
The backup camera seems a bit hazy even after cleaning the lens anyone else find this
Some webcams have a 'focus ring' to adjust the focus. I do not know if auto backup cams have such a thing built right onto the camera lens. Adjust that focus until the pic is clear.
2answers
Can't get slide projector to focus with lens in projector
Check the lenses inside the lens tube and see if they are loose or out of place
1helpful
GREEN CRT OUT OF FOCUS
The individual lens have a lug nut that when loosened allows the lens to be turned-----cover red and blue lens and call up the convergence grid---from the rear adjust that lens until the green lines are in good focus(can also do the red in and the blue if needed)
You will get no more advantage as the manual focus controls on the splitter block have very limited range.
when done carefully tighten the wing nuts on the lens back tight.
Canon Rebel EOS Rebel Ti1 will not auto focus
The lens needs servicing, because the lens is stiff the auto focus motor cannot turn the lens to focus.
Canon rebel T3 focus problems
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
My webcam is blury, How do i fix it?
Most WEBcam have a focus adjustment at the lens. Turn the focus ring in front of the lens to adjust the focus.
Blurry and dark webcam image even after i rotate lens
try adjusting the lens focus, the one I use has a screw in lens which adjusts the focus of the image being captured
2answers
Webcam
adjust the lens on the front turn it left or right until image is clear.
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
