Cameras Logo
Question about Nikon Cameras
My Nikon D3200 will not focus?
Have tried changing focus mode and nothing seems to work also tried in manual mode no luck either
Posted by Karen Hill on
tollertoller
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Let me start with a guess. There is a diopter adjuster just behind the viewfinder. If it is adjusted way off from the correction you need, everything will look no better than out of focus though your photos may look fine. Google how to adjust the diopter setting on the D3200 and see if that won't take care of the problem.
Here is one of the secrets: your camera has so many adjustments that if someone else picks up your camera, they may change a setting leaving you wondering what happened and why. Be cautious.
If that guess is not the cause, let us continue. Are you saying that when you switch the lens setting from A to M, it still will not manually focus? Some of the lenses are mostly made for autofocussing, so the focus ring that you have to turn for manual focus could be narrow and out at the very front of the lens. If you cannot manually focus, something may have happened to the inner works of your lens. Try another Nikon lens to see if it will autofocus. If it does, your lens requires servicing or replacing.
Good luck. Hope you get back to shooting soon.
Posted on Jan 02, 2019
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Marky
Posted on May 14, 2008
David E
  • 97 Answers
Dan62, your camera will never be able to focus on objects with no contrast. The manual specifically states this. However, you can put the AF marker over something with some contrast, half press the shutter, so that it will focus, hold the shutter button halfway while you recompose the shot, and then press it all the way.
A note to others using the D40/D40X/D60 that are having problems with autofocus: please remember that this camera will not autofocus with mechanically driven lenses. It will only AF with "AF-S" or "AF-I" lenses.
Posted on Sep 05, 2008
Anonymous
  • 9 Answers
SOURCE: Nikon D80
EXPLANATION.
1. The problem with 18-135 lens is because it make from plastic. Main problem from plastic is it can be reshaped after a few usage. When the shape ran out, the contact point will be defective. When the contact point didnt really touched, the processor cant send signal to lens to do autofocus (the lens focus using the lens motor, not the body). When u set to manual focus, the body doesnt need to instruct the lens to focus.
2. You are focusing something that is to near than the focal point.
SOLUTION.
1.Try cleaning the contact point on the lens. Then mount it back until the F showing up (F= aperture). This solution depend on your luck too. if the gap between to contact is so far, then it might happen back. Usually when u need it badly. haha
2. try to get more distance from your subject. Just keep press the shutter until the camera focus.
CONCLUSION
1.But new lens with metal mounting. It will last and durable.
2.Buy macro lens to close up. normal lens wont focus at short focal point!!~
Posted on Nov 04, 2008
fblock
Fred Block
  • 289 Answers
SOURCE: Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Posted on Apr 24, 2009
MIke
  • 685 Answers
SOURCE: My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
Posted on Nov 24, 2009
Nikon D90 is showing auto focus error while shooting other than manual mode
Hello Amian,
Here is a link to the manual of your camera that may be helpful to you.
Good luck,
JP
https://www.manualslib.com/manual/745954/Nikon-D90.html
Back focus?
that is a common problem, take the camera to a professional service for a calibration
I can't take a picture with my d3200 it make nose when I push the button and then nothing
Seems to be a lens autofocus problem.. lens needs repair. If your camera has inbuilt motor.. take it to service as soon as possible
I have a Nikon D3200 camera. When I'm in Guide mode, it switches to black and white pictures. Why? And how do I fix please
1) reset your camera from the menu .. check manual to do it.
2) guide mode must have sub modes like black and white etc .. see if your had kept in B/W as your settings.
1helpful
How can I determine which Sigma and Tamron lenses will work with my Nikon D3200? (I know they have to fit my Nikon F mount.)
There are three things you have to consider when getting lenses for the D3200.
First, you already know that the lens has to have the Nikon F mount.
Second, in order to autofocus, the lens must have a focus motor since the D3200 doesn't have one itself. Sigma designates lenses with the focus motor as HSM. Tamron designates theirs as USD. Lenses that don't have the focus motor will still work with the D3200, you just have to focus manually.
Third, the lens must have the electronics to communicate with the camera in order for the exposure meter to work. Any Sigma or Tamron lenses designed for digital cameras will have the electronics. Older mechanical lenses, including those from Nikon, will still work with the D3200, but you must set the exposure manually, without any help from the camera's light meter.
Nikon D5100 vs Nikon D3200
They both take superb pictures. The D3200 is slightly easier to learn how to use, while the D5100 is easier to use once you learn it. That is, the D3200's menus will guide you through all its settings, while with the D5100 you can change those settings with less work once you learn the proper buttons to push. The D3200 has a higher resolution, but even the D5100 will take photos that can be enlarged to 8x10 and larger.
I suggest you go to a good camera store and try them both out. See which one better fits your hands. You don't want to buy a camera based on specs, or other people's opinions. You want a camera that best works for YOU. Having said that, the D3200 is probably a better first SLR. However, try them both out and choose the one that's better for YOU.
2answers
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
3helpful
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
