Samsung HCM4216W 42 in. Rear Projection Television
Problems with Samsung HCM4216W 42 in. Rear Projection Television?
Troubleshooting and Support
Solved Problems for Samsung HCM4216W 42 in. Rear Projection Television RSS Feed Post a New Problem
Picture shadow on rear projection Sony big...
I have a 4 year old SONY big screen rear projection (not HDTV) TV. I am having problems with a shadow on every image in...
1 Solution
The colors primary red,green and blue...
hi all the colours on my screen are seperate, wathing football gives me 3 images of same player in differnt...
1 Solution
Samsug rear projection tv, everything...
I replaced the color wheel about a year ago and everything was fine. Now all of a sudden everything looks green, but...
1 Solution
SAMSUNG HCM4215W Rear Projection HDTV ...
Recently repaired the convergence problem with the tv; replace the two STKs, the pico fuse, and the fuse resistors....
1 Solution
Set shuts itself off
My set shuts itself off after a period ranging from minutes to hours. No normal "deedle deedle" shut-down...
1 Solution
TV does not turn on.
When I plug it into outlet relay inside clicks like tries to turn on in a few seconds clicks again and so on... LED next...
1 Solution
RED CONVERGENCE PROBLEM
THE RED CONVERGENCE HAS JUMPED OUT TO THE RIGHT AND WILL NOT COME BACK INTO FOCUS. CAN I FIX THIS?
1 Solution
Unsolved Support Problems
Unsolved Problems for Samsung HCM4216W 42 in. Rear Projection Television RSS Feed Post a New Problem
samsung rear projection model# 4365wx/xaa
tv before would sometimes not work with the remote or the buttons on the side of the tv. It woujd oly do it evry now and...
Post a Solution
42" Samsung TV won't turn on, red...
Hello, Hopefully someone out there can help me. My samsung HCM4215w will not turn on. It begins powering up, however...
Post a Solution
hi all the colours on my screen are seperate, wathing football gives me 3 images of same player in differnt colours...
Post a Solution
Hello, guys..my problem it s why the color primary they are not in one.. they are separetly in my screen..it s like when...
Post a Solution
set turns off and on
My set plays for a while ranging from a few minutes to a few hours and then makes the little beepy noise and shuts off...
Post a Solution
tv colours are out
i moved the television and now all the writing it blurred either side of the picture. the left and the right how do i...
Post a Solution
Timer Light.
I just got my convergence chips replaced, now when i turn on the tv the timer light blinks 10 times. Everything works...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size42 inch
Display Capabilities
Aspect Ratio16:9
Remote Control
Remote ControlMultibrand
Image Quality
Velocity Scan ModulationWith VSM
Comb FilterDigital 3-Line
Adjustable Color Temp.With Adjustable Color Temperature
Audio Features
Audio TypeStereo
MTS StereoSAP / MTS Stereo
Technical Features
Picture in PictureWith PIP
Energy Star CompliantEnergy Star Compliant
Dimensions
Depth17.75 in.
Height42.13 in.
Width39.44 in.
Weight108 lb.
Samsung Contact Information
Main support number1-800-SAMSUNG
Sponsored Links
Loading problems.
Top Experts
Ask Me
Slinterio Guru
119 solutions
Ask Me
premtech Guru
15 solutions
Ask Me
cycus Guru
6 solutions
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
