D-Link DIR-825 Wireless QuadBand Router Logo
Posted on Jun 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unstable wi-fi connection to D-link DIR-825
Hi. I have two laptops connected to Wi-Fi on My DIR-825. While one works OK in both, 2.4GHz and 5GHz (HP laptop), the other one (DELL Inspiron B1300) finds only 2.4GHz network. But this is not a problem at all. The problem is, that the Wi-Fi connection DELL-router is unstable. The Wi-Fi connection DELL - router wokrs for a few minutes (aprox. 5 minutes), then it disconnects and reconnects again. This goes on and on. I have checked settings on router, Wi-Fi driver on laptop, but everything seems to be OK. Do you have any idea, what could be the problem?
Raghavendra Nagaraj
Level 2:
New Friend:
  • Expert 116 Answers
  • Posted on Jun 17, 2010
Raghavendra Nagaraj
Expert
Level 2:
New Friend:
Answers
116
Questions
Helped
24742
Points
297
Check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
How do I Connect an iPhone to an HP printer without WiFi/Wireless?
Wi-Fi let's you connect devices Hassle-free without worrying about the wires and cables but sometimes Wi-Fi doesn't work and you need the prints in that case here's how to connect iPhone to HP printer without Wi-Fi. You would require a USB Cable for this and install the iPhone HP Printer app. Use the printer setup assistant to connect the printer to the Wi-Fi and then you can disconnect the USB cable. The printer should remain connected to the Wi-Fi. This would ensure that your devices have the internet without Wi-Fi. https://connectmyprinter.com/how-can-i-print-from-iphone-to-hp-printer/
Como hago para que prenda la luz de mi ax1560
Posted to 'Cars and Trucks' and appears to be a ROUTER, or a WATCH! Plus in Spanish in a site that is only English!
https://translate.google.ca/?sl=auto&tl=en&text=Como%20hago%20para%20que%20prenda%20la%20luz%20de%20mi%20ax1560%0ANo%20prende%20pero%20funciona%20todo%20sol%20que%20de%20noche%20no%20me%20sirve&op=translate
How do I turn on the light of my ax1560
It does not turn on but all sun works that at night does not serve me
ALL QUESTIONS 'Make Model (WHAT IT IS)'. Fark
EXO AX AX1500 Wi-Fi 6 Router DIR-X1560 - D-Link
https://www.dlink.com > products > dir-x1560-exo-ax-...
Wi-Fi 6 (802.11ax) technology provides faster speeds, greater capacity and less network congestion · Next-gen speeds up to 1.5 Gbps (1200 Mbps on the 5 GHz band ...
D-Link: EXO AX1560 Wi-Fi 6 Router Review - Impulse Gamer
https://www.impulsegamer.com > d-link-exo-ax1560-w...
Jul. 9, 2020 - D-Link: EXO AX1560 Wi-Fi 6 Router Review · Wi-Fi 6 (802.11ax) technology provides faster speeds, greater capacity and less network congestion ...
D-Link EXO Mesh AX1500 Wi-Fi 6 Router (DIR-X1560) Review
https://www.pcmag.com > ... > Wireless Routers
Jun. 30, 2020 - The D-Link DIR-X1560 is an under-$100, but relatively bare bones Wi-Fi 6 router that delivers decent 5GHz performance though its 2.4GHz ...
Rating: 3 · ‎Review by John R. Delaney · ‎US$74.00
Armani Exchange Men's AX1560 Active Watch Analog Display ...
https://www.amazon.ca > Armani-Exchange-AX1560-Acti...
Armani Exchange Men's AX1560 Active Watch Analog Display Analog Quartz Black Watch · Currently unavailable. We don't know when or if this item will be back in ...
My HP Elitebook 6930p wi-fi connection stopped working
It sounds like windows update may have changed your driver to a generic one. Download and install the driver again from the HP link for your model laptop here HP EliteBook 6930p Notebook PC
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
D-LINK DIR-815
Contact D-link support number 1-888-494-1155 (Toll-free) usa and find instant help by expert D-link technicians.
How do we get wi-fi on ipod touch
in i phone touch u have to manu Tap Settings > General > About and scroll down to Wi-Fi Address or Bluetooth then turn on wi fi detection and connect it
Connect Additional Computers to my network
ok
first install your wi fi network adapter driver in computer also if you have laptop then there is switch for wi fi on it.
Then go to my ntwork polaces there you see your wi fi network.
Also check your wi fi enabled in router .
Let me know
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Want Instant wi fi when turning on my laptop
Hp comes with a wi-fi utility and I dont find it very useful, so first, you might want to uninstall the software from add or remove programs and then use windows to manage your wi-fi.
Once you connect to a wireless network from 'network connections', it will automatically be set to default and should connect at the computer startup.
If it does not connect automatically.go to 'change order of prefered networks' and put your prefered network on top and set to automatically.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
