Sony DRU 510A DVD±RW Burner Logo
A
Anonymous Posted on Jun 14, 2010
Whenever I try to burn a cd it fails and comes up with an error 4280 message how do I fix this problem
Anonymous
Level 2:
Scholar:
  • Expert 128 Answers
  • Posted on Jun 14, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
128
Questions
0
Helped
56045
Points
298
Hi! I had the same problem before when writing files to disc. What i did was to lower down the speed ex. from 16x to min or from 4x or 8x to 16. That should also fix your problem.
Whenever I try to burn a cd in my DVD ram a message shows up saying it is not accessible, Incorrect function.? What do I do? ive tried to disable and enable the drive then reboot the sys., still the same...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. Thas basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
2answers
Error message when trying to burn a disc in i Tunes
The problem is with your optical unit, (TSST****), it must be firmware-updated, which version of iTunes do you have?
ITune fails to burn Cd on Sony AW-G170A Error 4280
It appears that lots of laptops need new hardware from the manufacturer - this should be available to download on their respective websites
My CD drive won't let me burn CD's anymore. Why?
Try choosing a different set of songs, if still your CD burning fails, try copying large chunk of data or a data cd to cd copy if possible. If this also fails, you have to give your cd burner for service / replacement based on the warranty entitled.
2answers
Windows xp installing failed
I assume you are trying to install XP from a self-burned CD.
Did you slipstream SP2 or SP3 in it?
If so, try to burn a DVD instead of a CD. I had that problem once too and followed some advice I found here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
2answers
I get an error 4280 when I attempt to burn an audio cd
Apparently a common error; if you google error 4280 you'll get several different versions of what is happening. Some blame the Sony CD's other blame Dell, HP, etc...like I said there is a long list so I didn't want to pick out just one, it depends on your Computer type, combined with the CDs..so go ahead and take a look. Personally from reading some of the fixes I came up with; don't use Sony disc and run at 16x to get rid of the error. Hope this helps..
Please rate this solution.
1helpful
I keep getting cancelled CD burns off of iTunes and Windows Media
I had that error befor I was burning with Memorex's 52x CD-R... when I switched to a Maxell's CD-R, the error was gone! And I left the burn speed at 'maximum'. It did it in about 4minutes. Good luck!
1helpful
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
