Hello
The E 15 error code is an indication of a water
temperature sensor error. There is a chance that there is a loose wire
connection on the water temperature
mean while E 15 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the
washer then clean up all forms of dry and water you can seen in it with
this the problem of the E 15 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
