white streaks on dark washing, whatever load, washing liquid, powder, conditioner or none. Hotpoint...
(More)
white streaks on dark washing, whatever load, washing liquid, powder, conditioner or none. Hotpoint WMD960. Tried everything in calgon. Daughter same machine,same problem. Never had it before on old machines.
Aeg Belgium tells us it's a problem with the print of the machine. You should ask AEG the reset...
(More)
Aeg Belgium tells us it's a problem with the print of the machine. You should ask AEG the reset code, you need to turn the knoughts in a certain combination after each other and your reset is complete. That's the only thing they can do for the moment. You're machine will work without problems untill the next time you need to reset it! Good luck with it, I hope my answer was usefull to you! Greetings from Belgium! RC
I can get the front wire loop off easily and have removed the top of the washing machine OK. Yes the...
(More)
I can get the front wire loop off easily and have removed the top of the washing machine OK. Yes the power is off before I started work. There seems to be amoulded concrete balance collar that is srewed onto the stationary outer drum that is stopping clear access to the inner strap. Is there a easy solution to removing and replacing the rubber seal as it is full of mildew and i have a new replacement. i have not removed the feed from the powder draw yet .
I have a lavamat 74950 the pump filter blocked (error E20) I have cleared that but now the machine...
(More)
I have a lavamat 74950 the pump filter blocked (error E20) I have cleared that but now the machine won't run, I had the problem before and the mechanic pressed a load of buttons to re-set the programme, does anyone know which buttons to press?
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the ?F21? error code. ?F21? is a Long Drain error. If the drain...
written by jsrock516
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain...
This advice is for Kenmore & Whirlpool TOP LOADING DIRECT DRIVE type washing machines. This is NOT for older models equipped with a wig-wag...
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines. The first thing to do is...
Welcome to Action Appliance Repair. We have bee... Read More
Welcome to Action Appliance Repair. We have been serving the greater Hartford and Springfield area for over 40 years. We are dedicated to working around your busy schedule. Please call now to receive the $25.00 discount coupon available. We are family owned since 1961. Call now for your free ph
