Proform 730 Folding Treadmill Model PFTL71104 - ! Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belt is off alignment - Proform 730 Folding Treadmill Model PFTL71104 - !
John Mazmanian
Level 3:
President:
  • Proform Master 832 Answers
  • Posted on May 31, 2010
John Mazmanian
Proform Master
Level 3:
President:
Answers
832
Questions
0
Helped
628628
Points
2056
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Belt diagram timing
I assume 4cyl?
  1. Loosen tensioner adjusting bolt.
  1. Using Camshaft Belt Tension Adjusting Tool T74P-6254-A, pry tensioner clockwise against spring tension as far as possible.
  1. Tighten adjusting bolt to hold tensioner in released position.
  1. Align crankshaft so number one piston is at TDC (top dead center) with crankshaft key pointing straight up and circle on crankshaft sprocket (6306) aligned with notch in engine front cover (6019) .
  1. Align triangle on camshaft sprocket with triangle on inner timing belt cover.
  1. Align diamond on oil pump sprocket with diamond on inner timing belt cover.
    Timing Mark Alignment
Como poner la banda de tienpo de un toyota camery
Installation
1.Install No. 2 idler pulley (if removed). Install and tighten bolt to specification. See TORQUE SPECIFICATIONS . Ensure idler pulley is clean and rotates smoothly. 2.Install No. 1 idler pulley and tension spring (if removed). Pry No. 1 idler pulley away from timing belt area as far as possible. Temporarily tighten No. 1 idler pulley bolt. Ensure idler pulley is clean and rotates smoothly. 3.Using crankshaft pulley bolt, rotate crankshaft so timing mark on crankshaft sprocket aligns with timing mark on oil pump housing. See. This will position keyway in crankshaft sprocket at 12 o'clock position.
CAUTION:If reusing timing belt, ensure reference marks on timing belt align with reference marks placed on crankshaft and camshaft sprockets. Ensure timing belt is installed in original direction of rotation.
4.Ensure all sprockets and idler pulleys are clean. Install timing belt on crankshaft sprocket, oil pump sprocket, No. 1 idler pulley, and then No. 2 idler pulley in sequence. 5.Install timing belt guide with cupped side away from crankshaft sprocket and flat side toward timing belt. Install No. 1 timing belt cover and new gasket. 6.Align crankshaft pulley key groove with key in crankshaft. Install crankshaft pulley. Install and tighten crankshaft pulley bolt to specification. 7.Rotate crankshaft clockwise so cylinder No. 1 is at TDC on compression stroke. Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover. If reusing timing belt, ensure reference mark on timing belt aligns with upper edge of No. 1 timing belt cover. 8.Rotate camshaft, and align hole in camshaft sprocket with alignment mark on camshaft bearing cap. See Fig. 2 . Install timing belt on camshaft sprocket. If reusing timing belt, ensure reference mark on timing belt aligns with the reference mark on camshaft sprocket. Ensure tension exists on timing belt between the crankshaft and camshaft sprockets.
CAUTION:DO NOT rotate crankshaft counterclockwise, as viewed from timing belt end of engine.
9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence.
7helpful
2answers
Need the timing marks for 2001 hyundai tiburon
1.5L And 1.6L Engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L DOHC engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L SOHC engines
1.5L Engines
Fig. Proper pulley alignment for timing belt installation at TDC-Hyundai 1.5L SOHC engines, 1.6L similar
1.8L (VIN M) And 2.0L (VIN F) Engines
Fig. Proper alignment of the timing belt alignment marks for belt removal and installation-Hyundai 1.8L and 2.0L (VIN F) engines
2.0L (VIN P) Engines
Fig. Oil pump and crankshaft inner timing belt sprocket alignment marks-Hyundai 2.0L (VIN P) engines
Fig. Timing belt sprocket alignment mark locations and positioning for belt removal and installation-Hyundai 2.0L (VIN P) engines
3.0L (VIN G)
Fig. Installation of the timing belt-3.0L (VIN G) engine
Fig. Timing belt sprocket alignment mark positioning for belt removal and installation-Hyundai 3.0L engine
Hope this helped (remember comment and rated this post).
Would like information on timing belt settings on a 1993 Isuzu Rodeo 4X4 3.2 We have already bought the book. It seems that the setting still are not what this particular motor/engine needs are there other...
look for timing marks????
Align groove of crankshaft timing pulley with mark on oil pump.
Align the marks on the camshaft timing pulleys with the corresponding dots on the front plate. (i can email pic if needed)
When timing marks are aligned, no pistons will be on T.D.C.
install timing belt. Align the dotted alignment mark on the timing belt with the mark on the crankshaft gear.
For correct belt installation, the letters the belt must be able to be read as viewed from the front of the vehicle. It is recommended for easy installation that the belt be secured with double clips after it is installed to each pulley. Align the alignment mark (white line) on the timing belt with the alignment mark on the RH bank camshaft timing pulley (on the left side as viewed from the front of the vehicle Secure the belt with a double clip.
Turn the crankshaft counterclockwise to remove the belt slack between the crankshaft timing pulley and the RH bank camshaft timing pulley.
Install the belt on the water pump pulley. Remove double clips from pulleys. Turn the crankshaft pulley clockwise by two turns. Measure the rod protrusion to ensure it is within the standard. Standard 4-6 mm (0.16-0.24 in)
13) If out of standard, remove pusher, loosen adjusting bolt, and readjust. (Repeat from step 11). Tighten adjusting bolt to the specified torque. Torque 42 N-m (31 lb-ft)
  1. Pusher
    • Tighten bolt to the specified torque.
Torque 19 N-m (19 lb-ft)
  1. Timing belt cover
    • Remove crankshaft pulley that was installed in step 9.
    • Tighten bolts to the specified torque.
Torque 17 N-m (12 lb-ft)
  1. Oil cooler hose
    • Tighten oil cooler hose bracket bolts to the specified torque.
Torque 22 N-m (16 lb-ft)
  1. Crankshaft pulley assembly
    • Using special tool J-8614-01, hold the crankshaft pulley.
    • Tighten center bolt to the specified torque.
Torque 167 N-m (123 lb-ft)
  1. Crankshaft pulley; P/S belt
    • Tighten fixing bolt to the specified torque.
Install the belt on the idler pulley.
4helpful
Timing belt timing marks, 1997 ford escort where are they?
Ford Escort/Tracer 1991-1999 Repair Guide
REMOVAL & INSTALLATION 1.8L Engine
(see Figures 1, 2, 3 and 4)
  1. Disconnect the negative battery cable.
  2. Remove the timing belt covers.
  3. Rotate the crankshaft and align the timing marks located on the camshaft pulleys and the seal plate.
  4. Remove the crankshaft pulley and hub.
  5. If the timing belt is to be reused, mark an arrow on the belt to indicate its rotational direction to enable correct re-installation.
  6. Loosen the timing belt tensioner lockbolt and remove the timing belt.
To install:
  1. Temporarily secure the timing belt tensioner in the far left position with the spring fully extended, then tighten the lockbolt.
  2. Make sure the timing marks on the timing belt pulley (crankshaft sprocket) and the engine block (oil pump housing) are aligned.
  3. Make sure the timing marks on the camshaft pulleys and the seal plate are aligned.
  4. Install the timing belt.
  5. Loosen the tensioner lockbolt. Using a suitable prying tool, position the timing belt tensioner so the timing belt is taut, then tighten the tensioner lockbolt.
  6. Turn the crankshaft two turns clockwise and align the timing belt pulley mark with the mark on the engine block.
Fig. 1: Timing marks are located on the camshaft pulleys as shown-1.8L engines
Fig. 2: Make sure that the crankshaft sprocket (timing belt pulley) and oil pump timing marks are aligned-1.8L engines
Fig. 3: Align the timing belt pulley mark with the tension set mark, at approximately the 10 o'clock position-1.8L engines
Fig. 4: Check the timing belt deflection at the location shown-1.8L engines
  1. Make sure the camshaft pulley marks are aligned with the seal plate marks.
If the timing marks are not aligned, remove the belt and repeat the procedure.
I hope help you with this; remember rated this help. Good luck.
8helpful
Where are the timing marks for a 03 lancer es
Review this diagrams:
Fig. Timing belt sprocket alignment -3.5L engine
Fig. Align the timing belt sprockets as indicated before removing the timing belt-1.5L engine
Fig. Align the timing belt sprockets as indicated before removing the timing belt-1995-00 1.5L engine
Fig. Camshaft and crankshaft sprocket alignment for proper timing belt replacement-1.8L and 2.0L SOHC engines
Fig. Silent shaft sprocket alignment marks for belt replacement-1.8L and 2.0L SOHC engines
I hope help you with this; remeber rated this help.
I need the timing to motor 3.2 .
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Remove the air cleaner assembly and intake air duct.
  4. Remove the upper fan shroud from the radiator.
  5. Remove the 4 nuts retaining the cooling fan assembly. Remove the cooling fan from the fan pulley.
  6. Loosen and remove the drive belts.
  7. Remove the upper timing belt covers.
  8. Remove the fan pulley assembly.
  9. Rotate the crankshaft to align the camshaft timing marks with the pointer dots on the back covers. Verify that the pointer on the crankshaft aligns with the mark on the lower timing cover.
    NOTE When the timing marks are aligned, the No. 2 piston is at Top Dead Center (TDC) compression.
    WARNING Align the camshaft and crankshaft sprockets with their alignment marks before removing the timing belt. Failure to align the belt and sprocket marks may result in valve damage.
  10. Use tool No. J-8614-01, or a suitable pulley holding tool to remove the crankshaft pulley center bolt. Remove the crankshaft pulley.
  11. If present, disconnect the 2 oil cooler hose bracket bolts on the timing cover. Move the oil cooler hoses and bracket off of the lower timing cover.
  12. Remove the lower timing belt cover.
  13. Remove the pusher assembly (tensioner) from below the belt tensioner pulley. The pusher rod must always face upward to prevent oil leakage. Depress the pusher rod, and insert a wire pin into the hole to keep the pusher rod retracted.
  14. Remove the timing belt.
  15. Inspect the water pump and replace it if there is any doubt about its condition.
  16. Repair any oil or coolant leaks before installing a new timing belt. If the timing belt has been contaminated with oil or coolant, or is damaged, it must be replaced.
    0900c1528002abd0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using a double clip to hold the belt in place-3.2L and 3.5L engines
    0900c1528002abd1.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. For maximum timing belt life, install the belt as shown-3.2L and 3.5L engines
    0900c1528002abd2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. View of timing belt tensioner and pusher-3.2L and 3.5L engines
    0900c1528002abd3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Timing mark alignment and timing belt routing-3.2L and 3.5L engines
    0900c1528002abd4.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. View of timing belt tensioner pusher-3.2L and 3.5L engines
To install:
  1. Verify that the sprocket timing marks are still aligned and that the groove and the keyway on the crankshaft timing sprocket align with the mark on the oil pump. The white pointers on the camshaft timing sprockets should align with the dots on the front plate.
  2. Install the timing belt. Use clips to secure the belt onto each sprocket until the installation is complete. Align the dotted marks on the timing belt with the timing mark opposite the groove on the crankshaft sprocket.
    NOTE The arrows on the timing belt must follow the belt-s direction of rotation. The manufacturer-s trademark on the belt-s spine should be readable left-to-right when the belt is installe
2helpful
Timing for tropper 6cly and 4 camshafts and 24 valves model 2000
Timing Belt
Removal
1. Disconnect battery ground cable.
2. Remove air cleaner assembly.
3. Remove radiator upper fan shroud from radiator.
4. Move drive belt tensioner to loose side using wrench
then remove drive belt.
850RW001
Legend
(1) Crankshaft Pulley
(2) Cooling Fan Pulley
(3) Tensioner
(4) Generator
(5) Air Conditioner Compressor
(6) Power Steering Oil Pump
(7) Drive Belt
5. Remove cooling fan assembly four nuts, then the
6. Remove cooling fan drive pulley assembly.
7. Remove idle pulley assembly.
8. Remove serpentine belt tensioner assembly.
9. Remove power steering pump assembly.
10.Remove crankshaft pulley assembly using
5–8840–0133–0 crankshaft holder, hold crankshaft
pulley remove center bolt, then the pulley.
11. Remove right side timing belt cover then left side
timing belt cover.
12. Remove lower timing belt cover
13. Remove pusher.
CAUTION: The pusher prevents air from entering
the oil chamber. Its rod must always be facing
upward.
014RW011
Legend
(1) Up Side
(2) Down Side
(3) Direction For Installation
(4) Locking Pin
14. Remove timing belt.
CAUTION:
1. Do not bend or twist the belt, otherwise its core
could be damaged. The belt should not be bent at
a radius less than 30 mm.
2. Do not allow oil or other chemical substances to
come in contact with the belt. They will shorten
the life.
3. Do not attempt to pry or stretch the belt with a
screw driver or any other tool during installation.
4. Store timing belt in a cool and dark place. Never
expose the belt direct sunlight or heat.
6A–30 ENGINE MECHANICAL
Installation
NOTE: For correct belt installation, the letter on the belt
vehicle.
014RY00042
Legend
(1) Crankshaft Timing Pulley
(2) RH Bank Camshaft Drive Gear Pulley
(3) Water Pump Pulley
(4) Idle Pulley
(5) LH Bank Camshaft Drive Gear Pulley
(6) Tension Pulley
014RY00043
Legend
(7) Alignment Mark on Oil Pump.
(8) Alignment Mark on Timing Belt
(9) Alignment Mark (notch) on Crankshaft Timing
Pulley.
(10) Alignment Mark (groove) on Crankshaft Timing
Pulley.
014RW006
Legend
(1) Timing Belt
(2) Engine Rotation Direction
(3) Cylinder Head Side
1. Install timing belt.
1. Align the mark (notch) of crankshaft timing pulley
(2) with mark on oil pump (1).
Align the mark (groove) on the crankshaft timing
pulley (3) with alignment mark (white dots line) on
the timing belt (4).
NOTE: When timing marks are aligned, No.2 piston will
be on Top Dead Center.
014RW003
Legend
(1) Alignment Mark on Oil Pump
(2) Groove on Crankshaft Timing Pulley
(3) Alignment Mark on Crankshaft Timing Pulley
(4) Alignment Mark on Timing Belt
ENGINE MECHANICAL 6A–31
2. Align the alignment mark on the RH bank
camshaft drive gear pulley (2) to the alignment
mark of the cylinder head cover RH (3).
3. Align the alignment mark (white line) on the timing
belt (1) with alignment mark on the RH bank
camshaft drive gear pulley (2) (on the left side as
viewed from the front of the vehicle) and put the
timing belt on the camshaft drive gear pulley.
Secure the belt with a double clip or equivalent
clip.
014RW00004
Legend
(1) Alignment Mark on Timing Belt (White line).
(2) Alignment Mark on Camshaft Drive Gear
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover RH.
4. Align the alignment mark on the LH bank
mark of the cylinder head cover LH (3).
5. Align the alignment mark (white line) on the timing
belt (1) with the alignment mark on the LH bank
camshaft drive gear pulley (2).
When aligning the timing marks, use a wrench to
turn the camshaft drive gear pulley, then set the
timing mark between timing belt and camshaft
drive gear pulley and put the timing belt on the
clip.
NOTE: It is recommended for easy installation that the
belt be secured with a double clip or equivalent clip after
it is installed the timing belt to each pulley.
014RW00005
Legend
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover LH.
6. Install crankshaft pulley temporarily and tighten
center bolt by hand (do not use a wrench).
Turn the crankshaft pulley clockwise to give some
and the RH bank camshaft drive gear pulley.
2. Install pusher and tighten bolt to the specified torque.
Torque : 25 N·m (2.5 Kg·m/18 lb ft)
1. Install the pusher while pushing the tension pulley
to the belt.
2. Pull out pin from the pusher.
NOTE: When reusing the pusher, press the pusher with
approximately 100Kg to retract the rod, and insert a pin
(1.4 mm piano wire).
014RW011
17helpful
2answers
Need instructions to replace 1993 Toyota Camry Timing Belt
Hi Kmcarroll77
TIMING BELT REPLACEMENT - 2.2L -1993 Toyota Camry
Installation
9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence. See Fig. 6 . On MR2, tighten engine
Hope this helps, don't forget to rate.
Lazaruselite
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
