Troubleshooting & Support
Problems & Solutions
I have a proform crosswalk
1) TRY TO CLEAN THE CONTACT, by corroded or dust, or loose connection(tight).2) try to open the control panel and clean with contact...
My Proform 380 treadmill will
ADJUST 1) Reed swithc and optic disk.If after you did these adjustments Not work, replace the sensors.
how do you take off the motor hood from a
normaly there are 3-4 screws in front of hood then you need to put the tread in closed positionand look for two more that go straight up...
i PROPPED UP MY PRO
There is a knob about halfway down or up, depending on how you are looking at it. You need to lift up or push up a little bit to take the...
my proform crosswalk model no H 29730 TREADMILL
if the motor controller card is the model MC_60 you should change D4015L diodes and SCR's S4015L but if MC_2100 you should change the...
I have a problem with
just change the Diodes D4015L and SCR´s S4015L whit a caugting buy the new change and ready or is a MC-2100 w / transformer just...
Even while on manual setting the speed
1. You may have a belt and deck problem. Test by the following procedure: a) without the power on stand on the walking belt b) push the...
How do I move my Proform Treadmill to another room
I have moved this treadmill several times since we bough it. Up and down stairs and from one room to another. I also used to be a mover so I...
icline does not work
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. Remove the motor from...
While trying to run the mat/track stops or
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller...
it keeps shuting down
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2....
problems with my pro form 540 treadmill
So after reading the post from EricLaw, I wanted to clarify his solution because it also worked for me. When you open up the console, you...
Speed indicator and belt problem
Under the motor hood by the front their is usually a speed sensor either not working or not adjust close to pulley where magnet is locate...
i have a pro form cross walk advanced 525x when i
the treadmill should have tension adjusting screws. they'd be on the back of the treadmill where the belt wraps around the rear roller,...
I need a manual to run the programs...can you help
Go to iconservice.com - pick replacement parts, enter your model number. At the top of the parts page is the link to the manuals. Be sure to...
Unsolved Problems
was walking and it kinda shorted out stopped then...
belt will not move at all
I propped up my Pro Form XP trainer 580 and the...
I propped up my Pro Form XP trainer 580 and the latch knob was laying on the floor. Is there any other way to lower the...
my treadmill belt appears to
my treadmill belt appears to be slack and when I try to tighten it it still does not run properly it tends to slow down....
On this answer is it the white lubricant?
On this answer is it the white lubricant? maxtreadmill * Rank: Guru Sports & Outdoors * Rating: 89%, 420...
Can you tell me where
Can you tell me where I can purchase a safety key for my Proform 525x treadmill?
comment puis je me procurer
comment puis je me procurer une autre carte pour le moteur, MC-2000ES ? le moteur se met en marche mais s'arrete aussi...
proform 500i treadmill is stuck in the incline
proform 500i treadmill is stuck in the incline position.
i have a pro form
i have a pro form 500 cx treadmill at home and it was working fine yesterday and when i turned it on today the belt part...
Manuals & Guides
TopDo you have a manual for Proform Crosswalk 500 Treadmill? - Upload it to FixYa!
Upload a manual for Proform Crosswalk 500 Treadmill
Specifications
TopProperties
Full Product Name:Proform Crosswalk 500 Treadmill
Brand:Proform
Sports Type:Personal Fitness
Fitness Type:Treadmills
What's your problem?
Fix-O-Meter
37,269
37,269 people have viewed this product
- 282 people asked about this product.
- 116 people found solutions for this product.
- 10 people have added this product.
TEST PROCEDURE...
Treadmill Parts...
