Free software
If this question relates to the Mac Driver for the Digigr8 camera,
The disk supplied does not seem to have a driver for the Mac and I can't find a driver anywhere.
However, I may have found the solution:
You need to hook up the camera directly to your mac - use a cable that you know works.
Turn on the camera.
It should read "PC Camera" on the little screen.
You need it to say "NSDC". To select NSCD you need to press the "Play/Pause" button. On my camera it is PINK and is the last button bottom row: immediately to the right of the "Down Arrow" button.
Your camera may have a different order so if my suggestion doesn't work just press all the buttons in turn until your screen title changes from PC Camera to NSDC.
The camera should then appear on your desktop as an "untitled" drive. You can then use it like a hard drive. Open it. Inside there will be a folder DCIM, inside that a folder 100MEDIA. The contents are your films and shots. Option+Drag them to your desktop.
When finished you should "eject" the camera HD by dragging to the trash.
FYI I am using Lepoard 10.5.4. (No idea if this is essential). I also opended Disk Utility and scanned for external drives which you may also need to try.
I found a link. Click here.
i need the software for this webcam
