SOURCE: canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
SOURCE: slow copying
normally, it's because you are copying in a high resolution. have a look at your user manual, lower the scan resolution and it should be a lot faster. Check that you're scanning in black and white -that can speed things up as well.
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
SOURCE: My canon imageclass mf4270 jams 90% of the time
Hello sir; Check the paper path carefully is there have anything block over there, especial at both end. is the paper jam everytime at same place? cleaning up the roller with alcohol.
SOURCE: USB connection not being recognized on Imageclass MF4270 all of a
First make sure that the USB cable is OK and use another if you have one. Then make sure that the laptops have working USB ports from Device Manager. If they are OK then try powering up the Canon again without the USB cable connected to see if any errors are reported and then plug it in to your laptop to see if it is recognised. Check the status of the Canon Print Driver settings. If this all fails then you may have defective USB ports on the Canon and will need to get them repaired.
