Televison & Video Logo
Posted on May 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The picture on our tevion television just disappeared. We have sound, but no picture at all. this happened very suddenly in the middle of a news broadcast.
Anonymous
Level 3:
President:
  • Master 1,099 Answers
  • Posted on Jun 01, 2010
Anonymous
Master
Level 3:
President:
Answers
1099
Questions
0
Helped
307513
Points
3433
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer.
Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board.
1helpful
WHEN MY FRIEND'S TEVION TELEVISION MODEL No. 3241TS IS TURNED ON, A PICTURE FLASHES ON THEN DISAPPEARS. SOUND IS STILL ON BUT NO PICTURE. THE SAME APPLIES IF CONNECTING AND PLAYING A DVD.
That sounds like the inverter board. I would go online and search for the inverter board for that model TV. Replacing it is a very simple task once you take the back of the TV off.
A horizontal white line is appears in my LG Flatron colour tv in the middle of screen suddenly and the pictures disappears but the sound keeps on but when i restart the tv the pictures comes what would be...
Tap the top of the TV and if the picture comes on in full screen then it is possible that there are DRY SOLDERING points on the board.
use a good iron to touch up the soldering on the vertical and horizontal sections, the driver IC's. get help if you are not able to do the job but it seems a minor job.
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
The picture has disappeared but the sound is working
Check the lamp first, especially if its the original. Also, observe the red LED on the front panel. It will often blink a code which can identify the problem.
michtech
Problem with Poloroid LCD 32 in. TV
stiv0's Support Profile at FixYa will give you detailed instructions for repairing your set
Screen went out
This sounds to me that you blew a fuse, or something wrong with the mainboard. im no expert, by any means...Have you taken up the courage to open it up? there is about 40 screws, just draw diagrams and such where it goes.. also, there are 2 small screws by where the computer and dhmi digit port are (like your comp at home) AND also the nut on the coax. after this, it's home freee. power is right on top middle. check out my other post for pics of it...Hope this helps!
1helpful
2answers
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
