Karcher K2.26 Electric Power Washer Logo
Posted on May 24, 2010
How do you reset a karcher pressure washer
The button pops up and wont go down aqnd is under the switch
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Jul 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
26655
Points
24
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
1helpful
2answers
How do I fix a problem with my Karcher K4 pressure washer.
Sharon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Grumpy gits and useful tips
How to FIX Karcher pressure washer
Karcher North America Home Garden Online Help
Karcher electric pressure washer help starting
The test / reset buttons are for a Ground Fault Interrupter built into the cord / washer. This device will help prevent deadly electric shock in the event of a malfunction - it is the same technology used in "GFI" electrical outlets located in bathrooms, outdoors, basements, etc.
You should have this serviced - or replaced before using.
Why does the hose pop out whenever I switch on my Karcher 5.600 pressure washer?
Are the threads on the end ok, if not it sounds like the bypass unloader valve is at fault.
Thanks qwashers
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
What to try when karcher pressure washer wont start//?
unit may have either a bad power switch or stuck flow switch normally located at the inlet of pump inside where you hook up the garden hose
1helpful
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
When i operate the switch on my karcher pressure washer the power wash does not operate.
But water comes out the end right? just under hose pressure only I bet. I have one of these units and every time I think it has gone bad I manage to find the problem. This unit not only has the switch on the front that needs to be on but it also has a safety switch on the plug where it plugs into a wall or extension cord. The last time I thought mine had gone bad it had actually blown the fuse. the unit was plugged into an outside outlet via extension cord. It just so happens that that is an GFCI outlet. I think the wife got water on the extension cord and that caused it to blow. So check:
The power switch on the front The safety switch on the cord, The outlet it is plugged into
Usually, for us, it is the button on the cord when it is plugged into an extension cord it always gets the test button bumped which shuts it down.
6helpful
Australian Karcher 2.91 intermitant start
Under the top cover there is a micro switch that sometimes dislodges
This switch is for auto cut off when you release the trigger
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
