engine will not turn-over. It is a Honda 11 HP, OHV on a Karcher Pressure Washer. It was running...
(More)
engine will not turn-over. It is a Honda 11 HP, OHV on a Karcher Pressure Washer. It was running fine for about 45 minutes. All of a sudden it stopped. When I tried to start it again, the engine is bound up so that the pull rope will not pull out at all. It has plenty of gas. The crank case is full of oil, not over full.
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up ,...
(More)
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
It is recommended that once pressure washer is in operation and water flow thru wand is there ,that you do not allow off period between burst of no...
written by jj505
All new users to pressure washers ...a good hint to remember when starting engine,be sure you are squeezing the water gun trigger allowing water to...
written by jj505
Precise Engine Repair proudly represents Briggs & Str... Read More
Precise Engine Repair proudly represents Briggs & Stratton, Honda, Kohler, Tecumseh, Onan engines and Drainzit oil drain systems. Our goal is to offer free information, along with giving you an outlet to buy genuine original equipment manufacturer (OEM) parts at a discount.
