20 Most Recent
Karcher 1750 psi Electric Pressure Washer Questions & Answers
Hi My karcher k3.65 jubilee is leaking water when
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Not much pressure
there is 3 pcs like a rubber cup inside the pump connected in the pistons maybe this is worn out already.
