Karcher pressure washer K378M wont start I have plugged in pressed the test and reset buttons and neither one of them work
The test / reset buttons are for a Ground Fault Interrupter built into the cord / washer. This device will help prevent deadly electric shock in the event of a malfunction - it is the same technology used in "GFI" electrical outlets located in bathrooms, outdoors, basements, etc.
You should have this serviced - or replaced before using.
I just took mine out of the box, never used but is way past it's return date and mine didn't work from the get go???
It's unfortunate that you can't return it for a free replacement - but the fact still remains that it will not offer the protection intended. Please have it serviced before use. Good luck!
