We are trying to put our 4 prong plug back on our dryer. it has a black, green, white and red wires. which goes where?
Easy enough, black and red go to either end terminal behind dryer(makes no difference which, the white MUST go to the center terminal, and teh sreen ground must be hoooked to the ground strap, probalby already a green wire screwed there already as well
SOURCE: REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
SOURCE: I have to change the
let me know if you need more help
Mike
SOURCE: changing a 3 prong dryer cord to a 4 prong dryer cord??
The information you need is provided in the following link:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the information carefully and if you need any further assistance, please let me know. I hope this helps.
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
SOURCE: hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.
hope that helps
good luck
ii have a 4 prung plug but don,t know where the ground part go, do it go on the out side of the panel? can you show me a picture?
I just trying to figure out where the green groung wire goes doesn't seem to be a spot for it
