Frigidaire FEQ332E / FEQ332ES Electric Dryer
Problems with Frigidaire FEQ332E / FEQ332ES Electric Dryer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Frigidaire FEQ332E / FEQ332ES Electric...
Troubleshooting and Support
Solved Problems for Frigidaire FEQ332E / FEQ332ES Electric Dryer RSS Feed
View More Results for Frigidaire FEQ332E / FEQ332ES Electric Dryer
Questions and Unsolved Support Problems
Unsolved Problems for Frigidaire FEQ332E / FEQ332ES Electric Dryer RSS Feed
Answer
There is a loud banging sound in dryer when in use . Almost like there are shoes in the dryer. Help!
Answer
Even on low heat the top of the dryer towards the rear is HOT, the back is hot enough to burn (I can... (More)
Answer
I have a dryer, not sure what model number is, but I checked to see if my clothes were done, and now... (More)
Answer
the condensed water collects in the bottom part of the dryer instead of collecting in the container... (More)
Answer
I have cleaned my lint filter as well as removed the casing for the lint area and gotten all the... (More)
Find a Manual
Frigidaire FEQ332E / FEQ332ES Electric Dryer Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
Tips & How To Guides for the Frigidaire FEQ332E / FEQ332ES Electric Dryer
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
When to Buy a New Dryer or Fix Old One?
If your old clothes dryer is not working well, how do you tell if it's time to replace it?Here are some things to check before you set it on the curb... written by smartr10U
New Clothes Dryer vs. Fix the OLD One
If your old clothes dryer isn't working well, how do you tell if it's time to replace it? Here are some things to check before you set it on the curb... written by smartr10U
Dryer Takes Too Long to Dry
This advice is for problems with a dryer that runs and heats, but takes entirely too long to dry. MOST dryer heat related problems are due to poor... written by jsrock516
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
Installing a 220 VAC Appliance Cord
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards). 3-Prong or 4-Prong ? The... written by jsrock516
Dryer Ducting Installation Advice
Here?s some useful guidance for installing dryer ducting. Improperly installed ducting can cause the following: GAS DRYERS ? Rapid burn cycling and... written by jsrock516
Thorough Dryer Advice
This advice is general in nature, but should assist you in isolating MOST dryer malfunctions. Normally when a dryer starts to exhibit longer dry... written by jsrock516
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Frigidaire FEQ332E / FEQ332ES Electric Dryer
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Ratings for the
Find a Warranty
Specifications for Frigidaire FEQ332E / FEQ332ES Electric Dryer
Key Features
Design
Free-Standing
Power Source
Electric
Volume
5.7 cu. ft.
Load Type
Front Loader
Dryer Type
Home Dryer
Stackable
Stackable
Other Features
Cycles
4 Cycles
Cool Down Feature
With Cool Down Feature
Moisture-Sensor
With Moisture-Sensor
Dimensions
Overall Depth
26.88 in.
Overall Height
36 in.
Overall Width (Display)
26.88 in.
Warranty
Warranty
1 Year
Frigidaire Contact Information
Main support number1 (800) 374-4432
Describe your problem:
Top Dryer Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
