My pc isn't doing anything at all.It camops and the ite on for a minute t cut off and never came on again.It doesn't make any noises at all.My pc isn't doing anything at all.It camops and the ite on for a minute t cut off and never came on again.It doesn't make any noises at all.
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help: Possible causes:
1. AC adapter failure. 2. Power jack failure. 3. Motherboard failure.
Possible troubleshooting steps and repair solutions: 1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
You need to telephone or email the tech support at gateway so that they can arrange for you to send the camera in after exhausting all troubleshooting options, with the technician.
go to the gateway 7330 page of the gateway official website. download the vista drivers for the system. when you want to install, right click and select "install with troubleshooting". then follow the instruction from there.
double check your power cord! i just went thru 3 days of troubleshooting my Gateway M6318. Thought it was my dc jack.... after tearing down my laptop... finding the jack in tact, soldering in tact. testing my power cord... off and on for 3 days.. it was reading 19v.. which is what it should... but as of today began zero reading on tester. Tomorrow I will buy a new power cord to see if this was the correct problem... wish i would have found the above reference site before all the other troubleshooting i had done... tearing down my lap top, pulling, tugging, twisting my power cord to get a good charge.... etc. hope this helps!
This is directly from Gateway's websit ein regards to this issue.
" How do I send my Gateway product for service and repair? You must contact a Gateway technician for authorization to send in a Gateway product for all in or out of warranty repairs. Upon exhausting troubleshooting resources, the technician will determine if a product requires service. Contact technical support through e-mail, chat or by calling the correct number as listed below.
You may also contact Gateway technical support at the following:
Home/Home Office Direct (For products purchased directly from Gateway on or after Jan. 1, 2005): (800) 846-2301
Home/Home Office Direct/Professional Direct (For products purchased directly from Gateway before Jan. 1, 2005): (800) 846-2301
Gateway Retail (Gateway products purchased from any vendor other than Gateway): (408) 273-0808
A little more information would be helpful.
What are you troubleshooting?
