20 Most Recent Gateway GTW-P42M102 Television Questions & Answers
have you replaced the battery and checked.
Gateway... | Answered on May 09, 2013
Every screen I've ever sween for sale is more expensive than a new tv itself. I'd try ebay or google and see if you can find one that doesnt work.
Thanks,
Michael
Gateway... | Answered on Feb 06, 2011
Standby means you haven't an oscillation which will drive your flyback. This is due to the ff reasons: -open fusible resistor in line with B+ to the H-out transistor. -shorted H-out transistor -Leak on 160v electrolytic cap. above is the common reason while below still to be consider. -Defective jungle IC -Defective System IC
This is not diy and I've advice to send your unit to repair shop to isolate the problem But check also if it is under warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Have a nice day! Thanks for using fixya.
Gateway... | Answered on Jan 27, 2011
Replace the power supply unit. www.shopjimmy.com my have the part.
Thanks
Gateway... | Answered on Nov 09, 2010
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Gateway... | Answered on Oct 30, 2010
i have the gtw-p42m102 and it did the scrolling thing and i had the image board dpwb11393-1g-l changed and it worked fine for 2 years.Now it made a pop like a firecracker and i am working in it now.
Gateway... | Answered on Aug 29, 2010
did anyone ever get this problem fixed with the gateway menu problem i have the same issue
i cant believe noone has fixed it yet...........i have 2 exact gateway tvs one has a bad image board and the other does the menu thing..i want to know which part to swith to get the menu to stop scrolling all the time
Gateway... | Answered on Jan 26, 2010
All voltage are OK if power supply is working alone. When the Y-sus board is plugged in, VE drops from 16V to about 4V. So the problem is onto the Y-sus board.
Gateway... | Answered on Jan 25, 2010
http://shop.adc-ast.com/cgi/display.cgi?item_num=DPWB11396-1G-T http://shop.adc-ast.com/cgi/display.cgi?item_num=DPWB11393-1G-L http://shop.adc-ast.com/cgi/display.cgi?item_num=PDP42WVSN3S
Gateway... | Answered on Nov 23, 2009
Hi.
Click the link below to download the complete service manual:
http://support.gateway.com/s/Manuals/HomeTheater/GTW-P42M203.pdf
Please do not forget to leave feedback.
Thanks.
Gateway... | Answered on Nov 19, 2009
Your main board needs replaced.
Gateway... | Answered on Nov 12, 2009
Hi.
If you have the hourglass and the TV shutting down , then the TV is crashing because the system fails to initialize. That can be bad firmware or bad digital controller board.
I don't thing that it is the power board either, but the power board must be tested the same by a technician.
Gateway... | Answered on Nov 03, 2009
check for loose connections power board,inverter board.good luck.
Gateway... | Answered on Oct 05, 2009
Televison & Video Logo
41 questions posted
Top Gateway Televison & Video Experts
Ronald
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Televison & Video
Most Popular Question
front glass broke
  • Televison & Video
