When u record music, its important that the background music be at -7db and the vocals should bounce the level meters to just over 0 db,also if u use a mixing console to add more instruments to the mix, the mixed output of the added content MUST BE NO MORE THAN -7db in order to maintain balanced music output to all channels.
some of them require red , white, blue, green, an yellow audio jacks. make sure you have all the input plugs. or eles the tv will not use plugs it doesnt have.
That sounds more like a polarity, or phase problem. Make sure your speakers are hooked up correctly, with the correct colors going to (+) positive, and (-) negative. Make sure your rca connection are correct, and that every connection has a left and a right. No stereo-to-mono adapters.
Is setting to "vocal" an eq selection, or a "dolby" stereo selection?
Are you using a dolby surround stereo receiver with left, right, center, rear, etc.?? If so, try turning off any effects, or anything that would send signal to the center speaker.
Lastly, depending on what the source of your music is, it is possible if your connections or receiver settings are not correct...that the music upon playback will be out of polarity, meaning the vocal portion will cancel out. Combining left and right signal together can sometimes do this as well.
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
There are a few things that may cause this to happen. First I would check your connections for your center channel speaker. in movies with 5.1 surround sound almost all the vocal tracks come out of the center channel.
Otherwise there maybe an issue with the volume levels for the center channel as well, these can normally be adjusted through the setup of your home theater system.
There's a multiplex button (MPX maybe) on the left front of the player. By hitting it you get leads only, background only or both. Be sure, though, you have a multiplex CD. Otherwise you'll only have background and no lead. I learned the hard way. Watch or scan for multiplex or lead vocals. Good luck...
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
