I can't believe the keyboard ever worked with a router. The keyboard worked with blue tooth to your tablet, or with a WIFi or blue tooth dongle in the computer..
The printer's IP address most likely needs to be changed. Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
1. check the router to see if you have a firmware update 2. check cables ( make sure you don't have a crossover cable. 3. check firewall in router and the PC OS ( operating system)environment. 4. check the setup for the XBOX
Reboot the router so that it can get a new dhcp lease.
If you can't login to the router to reboot it, just unplug the power for about a minute, then plug it back in.
If that doesn't work you will need to be able to login to the router to fix it. Depending on your internet supplier, you may have to set the router to login to the router.
I might advised you to call the PS3 manufacturer to gather the ports of the PS3 then you'll needing the help of netgear provider to open the ports of the PS3 to the router, so that the PS3 will allow to the firewall of your router.
If your new computer is a Vista box, my experience is that the DI-524 does not work with Vista. The DI-624 works well. Yes, I was annoyed to have to buy a new router too!
Did you run the initial CD?
What exactly are you having trouble with?
