You need to format it.. right click on disc and select format..
Hİ,
If your Avid FireWire driver needs update it may solve your problem.
To determine if your Avid FireWire drive needs updating, please click this link and do the procedures written there.
Hope this helps.
Hi
Thanks for using
FixYa. Please check that the CDs are not
scratched. Now run a lens cleaning
CD. If that does not work then you have to open the unit and clean the lens
with a Q-tip dipped in alcohol. This is only recommended when the unit is not
under warranty and you have some expertise in the field. Please check whether the
CD turns before moving to the next CD, CD moves freely and lifts into position. If still
the issue is not resolved then the lens is required to be replaced. Please do accept the solution if the
issue is resolved or post a comment for further assistance.
Thanks
Rylee
You haven't stated your problem, aside from the error code. Please include the hardware setup, computer and Pro Tools version and plugins you are using. Also include your experience with the setup; was it working at some point? etc.
I run PC and Mac versions of this system, and I have had to go as far as to enter the computer CMOS setup to sort out problems. Pro Tools issues can be caused by many aspects of your hardware and software setup.
I know it can be tedious and time consuming, but have you tried to access the Avid (Digidesign) site's Q & A locations? You may have to do this if the solution to your problem is not immediately apparent.
Most of all, if you are not running properly registered software, with a user account on Avid, you are asking for problems here. Cracked versions of the program and plugins can cause unresolve-able problems.
Try these Pro Tools related sites to see if they offer some help.
http://duc.digidesign.com/showthread.php?t=165488 RE: error code 1115
http://duc.digidesign.com/showthread.php?t=189857
http://www.sweetwater.com/forums/showthread.php?10723-Pro-Tools-headache..help-please
http://homerecording.com/bbs/showthread.php?t=288891
http://www.osd-uk.com/protoolsformedia/index.php/problem/tl-space-crashing-my-pro-tools-8-rig/
when it says disk not readable it is reffering to the hard drive not a cd
thanks for trying but i figured it out myself.. had to initilaze the drive by following mac prompt... hit erase twice and..BOOM!. it works?, maybe i should work for fixya??
