Question about Digidesign Mbox 2 Barebone
Installed pro tools 8 on macbook pro. when i try to open pro tools it says the hardware cannot be found. mbox2 is connected but the usb light is not on.
Posted by mitchnoakes on
bringit789
    New Friend:
I had this problem as well... If this is a 2011 macbook pro you have os 10.6.7 which is not supported by avid at this time. We actually need to down grade to 10.6.6. You installation cd with your macbook pro is 10.6.6, so you'll need to install that, then go to the avid website and download pro tool le 8.0.5. Everything should work fine just don't upgrade to 10.6.7 until it has been approved by avid. If you need detailed steps look at the avid forum for pro tools. Step to uninstalling and installing the os can be found on youtube.com... Do not have your mbox plugged in when you install pro tools. I hope this helps!!!
Posted on Mar 29, 2011
I can't get my Mbox2 to sync up to my MacBook Pro the green lights are on
Using Digidesign hardware involves an arcane recipe of the proper firmware, driver, and ProTools application versions, according to the subversion of the operating system. You have read that correctly: the viable brew of software versions can be influenced by even minor security updates to the operating system. Please submit a support request with Digidesign/Avid to sort this out; their tech support personnel are the only ones who have a complete understanding of how to resolve this.
Jul 15, 2014 | Computers & Internet
I need an activation code for pro tools 8?
When ProTools is installed on a computer it needs to be authorized to work. This has to be done via a dongle, a socalled iLok . The authorization is done by www.ilok.com. You need a dongle with the authorized registration of ProTools on your computer to make ProTools work.
regards
Mar 09, 2014 | Digidesign MBox2 Mini with Pro Tools 8 LE
Smartboard 580 is connected directly to my MacBook Pro by USB. The light on the smartboard flashes green for about a second when first connected, then stays as a fixed red. All attempts to fix come...
Ensure you have SMART Product Drivers installed through the Education Software Installer and that they are running on the MacBook Pro. More installation information is available in the SMART Notebook link here: http://www.smarttech.com/downloads. Select SMART Board Tools to open SMART's Control Panel and launch Connection Wizard to connect by USB or Serial cable. If require further assistance please contact SMART Customer Support from here: http://www.smarttech.com/contactsupport.
Aug 31, 2011 | Computers & Internet
When i plug in my mbox mini 3 the blue light come on, but when i try to lauch pro tools it says that hardware is not recognize. When look at the mbox mini control panel, it says that it is not connected...
Assuming you are on a Windows system, go to Control panel/Sounds and devices/ and check that the Mbox2 appears as the default in the Audio and also Voice tabs/panes while unit is connected. If it is not, select it in each... if it is not in the list offered, then the drivers have not been installed for the Mbox.
Aug 24, 2011 | Digidesign Mbox 2 Mini Workstation
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
My mbox2 will not install no more on my hp windows7 64bit get message Proot8 not vaild exec of win22. tried to install with hp support but could not
There has been a virus (nesky) that pertained to Win22.... if there is a chance you have that scaan for it first.
If that isn't the problem POSSIBLY an anti-virus program or anti_spyware is blocking it. Disconnect from teh internet and disable ALL these anti programs and try installing the Mbox2 again.
Last method would be to try installing it in SAFE mode if nothing else works.
Jan 05, 2011 | Digidesign MBox2 USB with Pro Tools 8 LE
Download tata indicom 1*usb modem installer for macbook pro
TATA Indicom's installation was pretty easy as they provide the modem
drives for mac. But the guys from Indicom may try hard to convince you
that Plug2Surf does not work and mac and you need their dialer to
connect to the internet.
1. Download the Mac Drivers for Qualcomm CDMA MSM modem.
2. The zip file you downloaded has to be unzipped. You'll see two
files inside, one for the Newer Intel x86 Macs and other one for the
Older PowerPC Macs. Open the appropriate installation (.pkg) file.
(Note : Unplug the device before opening the file.)
3. Click Continue.
4. In the next window, "Continue" after the reading the license and
then click "Install" .
6. Now open System Preferences > Network. You'll see "Qualcomm CDMA
Technologies MSM" on the left side bar (or it pops up a window, that
it has found it). Click on it.
7. Type Telephone No #777 , Account Name and Password both internet.
8. Click on "Advanced" > Select Vendor : Generic and Modem : Dialup
Device. Click "OK"
9. Your Done! The "Connect" button should be clickable now and will
connect to the Indicom service once clicked.
Mar 22, 2010 | Apple MacBook Pro Notebook
I am installing Pro Tool M-powered 8. after the installation i can't open pto-tools because of this prompt "unable to locate M-Audio hardware. Make sure your hardware is connected and turned on. Please...
SOMETIMES these systems require the software to be installed BEFORE the unit is connected to the PC.
Sometimes you have to install the software in "safe mode" to get it to work.
Oct 16, 2009 | Digidesign Pro Tools M-Powered 8
Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
Jul 22, 2008 | Digidesign Mbox 2 Barebone
Digidesign Mbox  2 Barebone Logo
311 people viewed this question
Top Digidesign Computers & Internet Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
matt
matt
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
