The machine was working just fine till I adjusted the thread density button, now it will not embroidery at all. I have changed the needle , thread and even the bobben thread and it still will not embroidery.
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
I ended up and took it to be repaired. It cost me 30 dollars, and they adjusted the tension on it. That was not to bad to pay. I thank you for your time
I have a Bernina can I change the density on embroidery pattern
