FixYa.com
Brother PE-150V Computerized Sewing Machine
All Products > Brother > Sewing Machines
Problems with Brother PE-150V Computerized Sewing Machine?
Troubleshooting and Support
Solved Problems for Brother PE-150V Computerized Sewing Machine RSS Feed Post a New Problem
Babylock Espree
The top thread keeps getting jammed up in the bobbin area. How do I fix this? I have changed the needle, rethreaded it,...
2 Solutions
brothers pe150 embroidery machine will not...
the machine was working just fine till I adjusted the thread density button, now it will not embroidery at all. I have...
1 Solution
Brother PE-150V bobbin thread
All of a sudden, whenever I attempt to embroider, the bobbin thread completely covers the upper thread on the top of the...
1 Solution
adjusting timing on brother pe 150...
How do I adjust the timing on my machine? My husband took off bottom plate and tightened the screws that hold the...
1 Solution
Brother PE 150 enbrodary. Need to
Brother PE 150 enbrodary. Need to have it repaired, Need to find a repair center in Missouri.
1 Solution
Threading
My PE`50 won't pick up the bobbon thread. I ran out of thread on the bobbin and rethreaded as usual, but not the needle...
1 Solution
brother PE150
Hi, I just got my PE150. It makes a few stitches, then the top thread winds loosley around the bobbin until the machine...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Brother PE-150V Computerized Sewing Machine RSS Feed Post a New Problem
Not picking up thread from bobbin
My machine is not picking up the thread from the bobbin. Watching the machine with the bobbin cover off I notices that...
Post a Solution
EMP6 Babylock
#4 thread path sews only a few stitches, then stops, doesn't break the thread, bobin thread is not broke, can restart by...
Post a Solution
Needle bent - thread break error
My wifes PE-150 starts to embroid , after a few stitches it comes up with the "needle bent or thread break...
Post a Solution
will not sew
I messed with the thread density and it will not sew even thou I put it back where it was
Post a Solution
Embroidery arm
I have a PE 150 it was sewing fine then the arm started only moving in a limited range what is wrong?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeComputerized
ThreadingAutomatic
Technical Features
LCD Design ScreenWith LCD Design Screen
Dimensions
Depth12.6 in.
Height13.4 in.
Width20.1 in.
Brother Contact Information
Main support number800-276-7746
Support FAX1-800-521-2846
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
