Power problems Hi, My tv worked fine. I turned it off one night and the next morning when I tried to turn it on I got nothing. There is no red light no green light. No signs of power. Help please I love my tv.
Hi, thanks I have a volt meter. I have power up to the fuse. I get a reading on one side of the fuse but no reading on the other side of the fuse. Any suggestionsHi, thanks I have a volt meter. I have power up to the fuse. I get a reading on one side of the fuse but no reading on the other side of the fuse. Any suggestions
You can't post conmments that contain an email address.
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. [email protected].
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
