FixYa.com
RCA L26W11 26 in. HDTV-Ready LCD Television
All Products > RCA > Flat Panel Televisions
Problems with RCA L26W11 26 in. HDTV-Ready LCD Television?
Troubleshooting and Support
Solved Problems for RCA L26W11 26 in. HDTV-Ready LCD Television RSS Feed Post a New Problem
High pitching sound
the other night I turned off the tv and there was a high pitching noise comming out of it. tried to turn the tv back on...
1 Solution
Power problems
Hi, My tv worked fine. I turned it off one night and the next morning when I tried to turn it on I got nothing. There is...
1 Solution
TV Screen not functioning correct
After turniong the set on for approximately 10 minutes, the screen will turn solid white and the backgriund sound is...
1 Solution
channels won't stay put
My rca L26W11 tv's channels won't stay on one channel. I have it on channel 4 which it should be on and it will...
1 Solution
just got digital hd
I just added hdtv and when I'm watching regular stations and even some HD stations it blacks out each side of the screen...
2 Solutions
Samsung DLP 61"
Can you help with this?
1 Solution
My set has quit working--the on/off switch does not operate. I am 100% sure the power supply is bad--the fuze did not...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for RCA L26W11 26 in. HDTV-Ready LCD Television RSS Feed Post a New Problem
Restricted Viewing Although Everything Is...
I keep getting a message saying something like "this channel has been restricted from viewing"... on the...
Post a Solution
i do not have a remote control for my tv i...
i need help i do not have a remote for the 26 inch hdtv model i have been using the top controls on the tv i do not have...
Post a Solution
rca L26W11
My rca tv won't stay on correct channel
Post a Solution
Problem Describtions/Diag.:Monitor powers up via CBL/SAT inputs. Receives video signal momentarely(3-5 minutes). Monitor...
Post a Solution
solution RCA L26W11 26 in. HDTV-Ready
talk to me buddy. Thanks in advance
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size26 inch
Contrast Ratio600:1
Digital TV StandardHDTV-Ready - Requires separate receiver to view HDTV signals. · HDTV-Ready
Flat Panel TypeLCD
Display Resolution1366 x 768 pixels
Display Capabilities
Built-in TunerNTSC
Broadcast Format Supported1080i (HDTV) · 480p (EDTV) · 720p (HDTV)
Broadcast Format Displayed480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Interpolated Aspect Ratio16:9, 14:9
Image Quality
Brightness500 cd/m??
Viewing Angle178
Adjustable Color TemperatureWith Adjustable Color Temperature
Remote Control
Remote ControlStandard
Illuminated RemoteNon-Illuminated
Audio Features
Audio OutputFixed
Audio TypeVirtual Surround
MTS StereoSAP / MTS Stereo
Technical Features
Parental ControlV-Chip
Sleep TimerWith Sleep Timer
Connectors
Headphone JackWith Headphone Jack
Rear Input ConnectorsRF x 1 · Audio (Mini Jack) x 1 · S-Video x 1 · Component x 1 · Composite x 3 · DVI x 1 · 1 x D-Sub (RGB PC) · Audio (RCA) x 4
Rear Output ConnectorsComposite x 1 · Audio (RCA) x 1
Screen Text
OSD LanguagesEnglish · French · Spanish
Channel LabelsWith Channel Labels
Closed Caption on MuteWithout Closed Caption On Mute
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 8 Watt
Dimensions
Depth4 in.
Height18.5 in.
Width31 in.
Weight46.3 lb.
RCA Contact Information
Main support number580-634-0151
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
