I can not find a diagram for the pinouts of the battery cable clip to fit the bottom of the tomtom rider v1 cradle in order to hardwire the mount onto a motorcycle, looking from the front of the cradle would you know which side is positive please?
SOURCE: Tomtom Rider v1
Send me an email at [email protected]. I have the solution but due to exceeding text length in the post I cannot give it to you through fixya.
SOURCE: Need tomtom rider 2 2nd addition docking shoe
Forget TomTom. Go buy this one
http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=8600880&Category_Code=
I talked to TomTom multiple times on the phone and had same problem but finally found this. It's better quality and it's available.
SOURCE: Tomtom rider 1 not charging when on bike
TOMTOM are VERY aware of this problem. but deny it is an issue!
I had the same problem, they sent me a new shoe after weeks of emails. I told them that the shoe is not the problem, it's the connector on the back of the TT1. Because of the springloaded pins fitted to the shoe and the poor quality connectors on the TT the normal vibration on a motorcycle causes the pins to wear holes in the connectors on the TT causing intermittant connection.
As the cost of repairing or replacing these connectors is very high and there are a large number of units that would require this repair TT are ignoring it.
I'm now looking at a way of bypassing the connector altogether.
A temporary solution appears to be to smear the contacts on the back of the rider with a little petroleum grease or WD40 - seems to work for a couple of weeks at a time.
SOURCE: tomtom Rider GPS won't turn on
My Tomtom rider 2 will not switch on. Battery has been on charge. Appears dead any solutions please?
Cy
SOURCE: Garmin Nuvi 750 car cradle/charger does not charge
Hi tbrick
if you dont have the original charger, the 750 take a special car charger because of the traffic feature...it has a flat end about 3/4" to 1" long that fits in the cradle, but you can use a garmin usb charger, you just wont be able to use the traffic feature.
if thats a little confusing ( i tend to do that) i try and explain it another way.
if you think you need or want one of those chargers, just post back to me.
bill
