My washer fills & over flows and won't start washing - doesn't stop @ any water level - with no alarms
Under the Pannel with all the LED lights there is a preasure switch with a plastic hose .
Remove the plastic hose on the RH side of the M/Cand obtain a 300 mm length hose and the same internal diamenter as the original
Push the hose on where the other one came off start Machine and when water starts to flow for approx 1 minut blow into the hose and the water should stop.
If not you have a stuck or dammaged preasure switch .
If it is stuck then turn off power and blow several times into the hose to free it up.
It will not start while in this mode.
Hope this helps.
Greg.
Check your pressure switch
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
i just replaced the pressure switch, i ran 4 loads on the 5th it over flowed again.
